iPhone presence detection
I am looking for an iPhone presence detection solution.
I found many iPhone detection bash scripts like this one
script (/opt/openhab/iphonedetect.sh) #!/bin/bash MAC=${2//-/:} declare -a DEVICES hping3 -2 -c 10 -p 5353 -i u1 $1 -q >/dev/null 2>&1 DEVICES=arp -an | awk '{print $4}' CHECK=$MAC if [[ ${DEVICES[*]} =~ $CHECK ]] then echo "ON" else echo "OFF" fi
But nothing in lua.
Did anyone over here already implemented a script and wants to share this?
Nicky
Here is Bluetooth device presence script which changes value of respective grp addresses based on Bluetooth device appearance.
require('ble') -- enable ble ble.up() list = {} -- mac -> group address mapping known = {  ['88:0F:10:10:F2:8A'] = '1/1/1',  ['88:0F:10:4A:2C:36'] = '1/1/2', } ctime = os.time() function callback(addr)  local now, delta  now = os.time()  delta = now - ctime  if addr then    if not list[ addr ] then      log('BLE found ' .. addr)      if known[ addr ] then        grp.write(known[ addr ], true, dt.bool)      end    end    list[ addr ] = now  end  -- check for missing devices each 5 seconds  if delta < 0 or delta > 5 then    for addr, time in pairs(list) do      delta = now - time      if delta < 0 or delta > 60 then        log('BLE missing ' .. addr)        list[ addr ] = nil        if known[ addr ] then          grp.write(known[ addr ], false, dt.bool)        end      end    end    ctime = now  end end ble.scan(callback)
That shell solution assumes that your iOS device has a fixed IP, you can do in Lua like this. I cannot guarantee that this code will work, you have to try and debug it yourself Smile
function checkiosdev(ip)   local sock, res   sock = require('socket').udp()   for i = 1, 10 do     sock:sendto('123', ip, 5353)     os.sleep(1)   end   res = os.execute('ping -c 2 -W 10 ' .. ip)   return res == 0 end seen = checkiosdev('192.168.1.10') grp.update('1/1/1', seen)
When phone/tablet is locked (in sleep state) sending UDP packets to port 5353 causes it to wake for a short period. During that period device can be pinged to check if it's in the network or not.
Perfect, that is the solution I was looking for.
Thanks a lot
superb! created a user library with the function and a resident for the few IPs I need to check.
Hi Admin,
I tested this script, created a log on the output and i see that there is a lot of toggle (on/off) even when the phone is all the time in the network.
Could it be that the wake-up methode by udp is not stable? You send it 10 times now for a special reason?
i found a useful app, https://packetsender.com/download, used this to send to port 5353. Then I had used a command prompt with ping -t to my iphone. I noticed that if you try to send multiple times the iphone would not respond to the ping.
Thanks,
Roger
Well, I don't have a device to test this script so any corrections are welcome. Another approach is to get DHCP client list from a router, then you don't have to set static IP and there's no need for UDP quirks Smile
I tried the Bluetooth device presence script but I have some problems.
  • I can only find BLE devices (watches and bands). I'd like to use it to detect smartphones (Android/Iphone).
  • The grp.write function doesn't work. I'm having trouble debugging this. I tried putting log('debug') in many places and never get results...
Thank you in advance,
André Neves
I´ve tried this script but it doesn´t work if iphone is locked. When I unlock if work perfectly.
With android devices it works perfectly.
Any Idea?
When iphone is locked the system turns off wifi. I think each 5min the system turns on wifi to search new inputs and then turns off again.
I was trying this. You can try it doing an infinite ping with cmd and lock/unlock the iphone. You will see!
There's no 100% correct way of doing this, the best approach is to get DHCP lease list from router and check if certain MAC is present or not.
Here is example with Microtik router
https://forum.logicmachine.net/showthrea...57#pid7657
I´ve seen microtic example but I don´t know how to do that with my livebox fibra...
(26.08.2016, 06:14)edgars Wrote: Here is Bluetooth device presence script which changes value of respective grp addresses based on Bluetooth device appearance.
Where should i put that code? In Common Functions or in Resident script?
This code is executed once or like resident script?
If you have BLE then just use general profile for presence. LM will see only broadcast messages but not every mobile is sending them.
If it does then you will see your device on the list. Works well with all the wearables.
I have a LM5 Power with Trust 18187 and I´ve done this tutorial:
http://openrb.com/lm-as-bluetooth-4-0-gateway/.
I've imported General Profile but Ble tab only discover 1 device. A TV but nothing with iphone ore android phones..
This is because smartphones usually do not send anything only want to receive. On android I found an app which can generate beacon and then it worked on LM. Probably you can find something like that for iPhone.
(07.08.2018, 14:37)Daniel. Wrote: This is because smartphones usually do not send anything only want to receive. On android I found an app which can generate beacon and then it worked on LM. Probably you can find something like that for iPhone.
what is the application for android?
Beacon Simulator or something like that. I just tried it and uninstalled afterwords.
