I 'm testing our business mail, that are the parameters:
Impostazione SMTP
Nome server: smtp.office365.com
Porta: 587
Metodo di crittografia: TLS
in common fuctions I have
local settings = {
from = 'segnalazioni.tecniche@komponext.it',
-- smtp username
user = 'segnalazioni.tecniche@komponext.it',
-- smtp password
password = 'xxxxxxxx',
-- smtp server
server = 'smtp.office365.com',
-- smtp server port
port = 587,
secure = 'sslv23',
I have to change or disable secure = 'sslv23' since I will use 587 port?
(27.11.2020, 08:26)admin Wrote: MS email should work, but better to try it yourself.
I have had the same issues as described in this thread. I tried now the solution with MS, and that worked.
I have one question thouh; If I have the mail settings in a userlibrary where the 'Keep source' is unchecked, is it 100% impossible to get to the library later?
The reason I ask is clear; I will have to enter company-sesitive information in the mail settings, and if it in any way is possible to read these settings later, this would be a big problem.
There are 10 kinds of people in the world; those who can read binary and those who don't
Hiding the source will provide some level of protection but it is still possible to retrieve the credentials from the backup file. I don't see a big security risk if you create a separate e-mail account for LM notifications.
(06.01.2021, 08:09)admin Wrote: Hiding the source will provide some level of protection but it is still possible to retrieve the credentials from the backup file. I don't see a big security risk if you create a separate e-mail account for LM notifications.
OK, thanks for answer.
I tested also the services you mentioned in an earlier post. I think I will go for one of them, then there is only the risk of giviing away credentials to a free service that is in no other way linked to my company.
Thx for help.
