TCP over SSL
Question
anybody had any success creating an SSL server listener in LUA ?
There seems to be an issue with the server socket not being able to receive() from the client. Sending from server to client however, works just fine.
Note that I tried using it in a copas handler first, and then as a simple standalone luasec handler (running on my machine, not in LM)
Simple test code looks like this:
local socket = require("socket") local ssl    = require("ssl") local params = {    mode = "server",    protocol = "tlsv1_2",    key = "C:\\ .... \\serverkey.pem",    certificate  = "C:\\ .... \\server.pem",    cafile = "C:\\ .... \\root.pem",    verify = {"peer", "fail_if_no_peer_cert"},    options = "all", } local server = socket.tcp() local ctx = assert(ssl.newcontext(params)) server:setoption('reuseaddr', true) assert( server:bind("10.20.2.92", 2000) ) server:listen() local peer = server:accept() peer = assert( ssl.wrap(peer, ctx) ) peer:dohandshake() data = peer:receive()  -- <--- HANGS ! print("receieved: " .. data) peer:send("Pong!\n") peer:close()
SSL server is not yet supported, we'll try to prepare an update this week though Smile
(01.11.2016, 09:30)admin Wrote: SSL server is not yet supported, we'll try to prepare an update this week though Smile
Ok ! I assume it will be via luasec ?
I got my code working though, turned out to be a hickup on the client side.
Hi Admin,
Is there any update on running an ssl server on the lm? Can this be done without a cert?
Thanks,
Roger
It's possible, but you cannot run it without a certificate. You can reuse web-server's self-signed certificate though. Here's a short example:
if not tcpserver then   require('copas')   sslparams = {     mode = 'server',     protocol = 'tlsv12',     key = '/etc/nginx_sha256.key',     certificate = '/etc/nginx_sha256.crt',     options = 'all',   }   -- connection handler   function connhandler(sock)     local ip, port = sock:getpeername()     sock = copas.wrap(sock, sslparams)     sock:dohandshake()     alert('[server] connection from %s:%d', ip, port)     -- main reader loop     while true do       -- wait for single line of data (until \n, \r is ignored)       local data, err = copas.receive(sock, '*l')       -- error while receiving       if err then         alert('[server] closed connection from %s:%d', ip, port)         return       end       -- handle data frame       if data == 'HELLO' then         sock:send('HELLO TO YOU\r\n')         sock:close()       end     end   end   -- bind to port 12345   tcpserver = socket.bind('*', 12345)   -- error while binding, try again later   if not tcpserver then     os.sleep(5)     error('[server] error: cannot bind')   end   -- set server connection handler   copas.addserver(tcpserver, connhandler) end copas.step(1)
Thanks Admin, that works..
Hi Admin,
A couple of questions,
Will this server support multiple clients? I added a basic authentication, that just sets a global variable on connecting and closes the connection if the password is incorrect.
The data received is passed another function parseC. Now I need to be able to respond back to the connected client where I declared a global function in this handler. Is this the right way to do this?
-- handle data frame       if data then        if(first==true)then           if(data ~='mypassword')then             first=false             sock:close()           end         end         Sclient= function (param)           sock:send(param)         end         local fd,prtd = pcall(parseC,data)                     if(fd==false)then                         alert("[elk-client] Error with parsemsg %s ",prtd)                     end       end
Thanks,
Roger
Yes, it supports multiple clients.
See this example on how to pass data to all connected clients:
http://openrb.com/example-lm2-as-tcp-ser...-requests/
You can pass any number of arguments via pcall, you can pass both data and socket if you want to send a reply to a specific client.
