Easee EV Charger
Hello, any ideas on how to integrate this?
https://api.easee.cloud/index.html
I've found a Python script on github, is it possible to convert this in any way?
https://github.com/fondberg/pyeasee
Regards..
This is a similar API: https://forum.logicmachine.net/showthread.php?tid=1786
There's a difference in login procedure (GetToken function). You need to set the 'content-type' header to 'application/json' and send username/password as json string:
request_body= json.encode({   userName = 'aaa',   password = 'bbb', })
Thanks, it works.
What would be the best way if i wanted the connection to the API to stay active, and then run seperate scripts for various commands?
It's not best practise to request new tokens for every command.
Create a scheduled script that will call GetToken() periodically and save the token into storage. All other scripts will use this token to make requests.
Check the expiresIn field that /api/accounts/token returns. It will tell for how many seconds the token is valid. Adjust scheduled script execution period accordingly.
(15.04.2021, 19:56)tomnord Wrote: Thanks, it works.
Did you get your script to work?
Are you willing to share your script and the commands for the Easee charger?
that would be very nice and would save me a lot of time :-)
Works like a charm. I'll post when I have access to my LM again.
(28.01.2022, 16:28)tomnord Wrote: Works like a charm. I'll post when I have access to my LM again.
Hi soo exaited about this!
Will you post it? Or sent it on PM?
-- Load modules require('json') require('ssl.https') require('ltn12') -- Set credentials for Easee API ChargerID = storage.get('EaseeAPI_ChargerID') API_Token = storage.get('EaseeAPI_Token')  --reads API Token from storage, The token is fetched from scheduled script: "Easee_Authenticate" --log(ChargerID) function RequestFromEasee(request)   request_url = 'https://api.easee.cloud/api/' .. request   local response_body = {}   local request_body = ""   local body, code, hdrs, stat = ssl.https.request{     url = request_url;     method = "GET";     headers =     {       ["Content-Type"] = "application/json";       ["Authorization"] = "Bearer " .. API_Token;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   log(code)   if code == 200 then     ret = table.concat(response_body)     ret = json.pdecode(ret)     return ret   else     --API_Token = GetToken() -- request a new token   end end -- Get products, run once to get charger ID if ChargerID == nil then chargers = RequestFromEasee('chargers') Easee_ChargerID = chargers[1]["id"] --log(Easee_ChargerID, 'ID') -- Check here for your charger ID storage.set('EaseeAPI_ChargerID', Easee_ChargerID) end ChargerState = RequestFromEasee('chargers/' .. ChargerID  .. '/state') log(ChargerState) currentChargePower = ChargerState["totalPower"] currentCableRating = ChargerState["cableRating"] currentMaxPower = ChargerState["outputCurrent"] chargerOnline = ChargerState["isOnline"] currentChargeEnergy = ChargerState["sessionEnergy"] log(currentChargePower, currentCableRating, currentMaxPower, chargerOnline, currentChargeEnergy) function WriteToEasee(request, request_body)   request_url = 'https://api.easee.cloud/api/' .. request   local response_body = {}   local content_length   if type(request_body) == "string" then     content_length = #request_body   else     request_body = ""   end   local body, code, hdrs, stat = ssl.https.request{     url = request_url;     method = "POST";     headers =     {       ["Content-Type"] = "application/json";       ["Authorization"] = "Bearer " .. API_Token;       ["Content-Length"] = content_length;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   log(code)   if code == 200 then     ret = table.concat(response_body)     ret = json.pdecode(ret)     return ret   else     API_Token = GetToken() -- request a new token   end end
require('json') require('ssl.https') require('ltn12') -- Set credentials for Easee API email ='****************' password ='*************' function GetToken()   request_token_url = 'https://api.easee.cloud/api/accounts/login'   local response_body = {}   local request_body = json.encode({       userName = email,       password = password, })   local body, code, hdrs, stat = ssl.https.request{     url = request_token_url;     method = "POST";     headers =     {       ["Content-Type"] = "application/json";       ["Content-Length"] = #request_body;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   log(code)   if code == 200 then     ret = table.concat(response_body)     ret = json.pdecode(ret)     log(ret)     return ret.accessToken   end end -- Request token if not API_Token then     API_Token = GetToken()       log(API_Token, 'api_token') end --Store API Token to memory storage.set('EaseeAPI_Token', API_Token)
Here is a script I use at a client's company to visualize the current charging power at each charging point in their company parking lot. Thank you tomnord for the earlier scrips Smile
-- Load required libraries once require('json') require('ssl.https') require('ltn12') -- Your configuration local API_Token = storage.get('EaseeAPI_Token') -- Define all 8 charging stations with placeholder names, IDs and KNX group addresses local chargingStations = {   { name = 'charger 1', id = 'charger 1 id', ga = '55/1/1' },   { name = 'charger 2', id = 'charger 2 id', ga = '55/1/2' },   { name = 'charger 3', id = 'charger 3 id', ga = '55/1/3' },   { name = 'charger 4', id = 'charger 4 id', ga = '55/1/4' },   { name = 'charger 5', id = 'charger 5 id', ga = '55/1/5' },   { name = 'charger 6', id = 'charger 6 id', ga = '55/1/6' },   { name = 'charger 7', id = 'charger 7 id', ga = '55/1/7' },   { name = 'charger 8', id = 'charger 8 id', ga = '55/1/8' }, } -- Function for making a GET request to the Easee API local function RequestFromEasee(endpoint)   local url      = 'https://api.easee.cloud/api/' .. endpoint   local response = {}   local _, code  = ssl.https.request{     url    = url,     method  = "GET",     headers = {       ["Content-Type"]  = "application/json",       ["Authorization"] = "Bearer " .. API_Token,     },     sink = ltn12.sink.table(response),   }   if code == 200 then     return json.pdecode(table.concat(response))   else     log('Easee API error (' .. endpoint .. '): ' .. tostring(code))     return nil   end end -- Parameters for power calculation local voltage = 230    -- V per phase local phases  = 3      -- three-phase local cosFi  = 0.95  -- power factor, adjust if needed -- Loop over all charging stations for _, station in ipairs(chargingStations) do   -- Fetch status   local state = RequestFromEasee('chargers/' .. station.id .. '/state')   if state then     -- Try to use totalPower directly     local power = state.totalPower     if not power or power == 0 then       -- Fallback: calculate using I × U × √3 × cosφ       local current = state.outputCurrent or 0       power = (current * voltage * phases * cosFi) / 1000  -- in kW     end     -- Send power (kW) to the configured KNX group address     grp.write(station.ga, power)   else     log('Could not retrieve status for ' .. station.name .. ' (' .. station.id .. ')')   end end
I am trying to write a certain setting to my Easee charger. I am monitoring my energy consumption and if the consumption in my house goes above a certain threshold, I would like to reduce the maxchargercurrent on my Easee chargers.
To stop, pause, resume and start charging I can send following comand:
"WriteToEasee('chargers/CHARGERID/commands/pause_charging"
However to change settings this does not work, as example:
WriteToEasee('chargers/CHARGERID/settings?maxChargerCurrent=10')
I assume this is linked to some APPLICATION/JSON... that goes above my level of skillset...
Anyone know who to send changes in settings?
This is the API descriptions
https://developer.easee.com/reference/ch...gersetting
Help is very much appreciated Big Grin
Mr.D
Try this:
WriteToEasee('chargers/CHARGERID/settings', '{"maxChargerCurrent":10}')
If it does not work then add more logging to WriteToEasee(). Replace log(code) with log(body, code, hdrs, stat, response_body)
(17.02.2026, 11:59)admin Wrote: Try this:
Thanks Smile It worked!
Mr.D
