Air conditioning
Dear readers,
I am looking for the following:
I have an air conditioning control but when the desired temperature is reached the fan continues to run.
now I want to switch off the air conditioning completely on the basis of the desired temperature and the current temperature and also on again with a hysteresis.
Desired temperature 5/2/14
Current temperature 5/1/14
air conditioning on off 6/1/0 1 byte object and must have a 0 for off and a 3 for heating and 9 for cooling
Can someone please help?
Hello, here is a script, you can make it resident.
summer = grp.getvalue('6/1/1') -- boolean if '0' is winter, if '1' is summer winter = not summer   current = grp.getvalue('5/1/14') setpoint = grp.getvalue('5/2/14') running = grp.getvalue('6/1/0') ~= 0 hysteresis = 0.5 value = nil if (running and summer) then   if current < (setpoint - hysteresis) then     value = 0 -- off   end elseif (summer and current > (setpoint + hysteresis) ) then   value = 9 -- cooling end if(running and winter) then   if current > (setpoint + hysteresis) then     value = 0 -- off   end elseif (winter and current < (setpoint - hysteresis) ) then   value = 3 -- heating end if value then   grp.write('6/1/0', value) end
