20.12.2023, 16:03
I have encountered an issue where the script section responsible for heat pump cooling sometimes runs unexpectedly, even though the conditions for its execution are not met. By using the log function, I identified that the variable `holas = '3/0/1'` activated this script, despite no conditions being met to proceed with the script. Upon checking the log, I noticed that the variable `thermostat_Heating_Cooling` was holding the value 1, indicating that it shouldn't proceed with the script execution.
Is it possible for variables to lose their value at times?
The addresses listed have assigned tags that can trigger the script
holas = '3/0/1'
svetainė = '3/0/3'
kambario = '3/0/4'
miegamojo = '3/0/5'
vonia = '3/0/6'
thermostat_Heating_Cooling = '3/6/20'
sildymas_siurb_arba_centrin = '6/1/13'
sil_siurb_heat_seatpoint = '11/1/16'
sil_siurb_cool_seatpoint = '11/1/15'
holas = '3/0/1'
svetainė = '3/0/3'
kambario = '3/0/4'
miegamojo = '3/0/5'
vonia = '3/0/6'
trieigio_PID_enabled_disabled = '3/5/20'
sil_siurb_onoff = '11/1/21'
sil_siurb_cool_heat = '11/1/20'
sil_siurb_cool_heat_setpoint = '11/1/3'
dv1_voztuvas = '4/5/13'
dv2_voztuvas = '4/5/14'
srb1_cirkuliacinis = '4/5/11'
srb2_cirkuliacinis = '4/5/12'
esamas_klimato_rezimas = '6/1/7'
holas = '3/0/1'
svetainė = '3/0/3'
kambario = '3/0/4'
miegamojo = '3/0/5'
vonia = '3/0/6'
adresas = event.dst
--************************Debugging*********************************
local function logEventWithAddress(event, address)
log("Event triggered by address " .. address .. ": " .. event)
--*********************Valve control - central heating**************************************
if adresas == sildymas_siurb_arba_centrin or adresas == thermostat_Heating_Cooling then
if not grp.getvalue(sildymas_siurb_arba_centrin)
and grp.getvalue(thermostat_Heating_Cooling)
then
grp.checkwrite (sil_siurb_cool_heat, true)
os.sleep(1)
grp.checkwrite (srb1_cirkuliacinis,true)
grp.checkwrite (sil_siurb_onoff, false)
grp.checkwrite (dv1_voztuvas,true)
grp.checkwrite (dv2_voztuvas,false)
grp.checkwrite (trieigio_PID_enabled_disabled, false)
logEventWithAddress("Valve control - Central heating", adresas)
--*********************Valve control - Heat pump heating**************************************
if grp.getvalue(sildymas_siurb_arba_centrin)
then
os.sleep(1)
grp.checkwrite (srb1_cirkuliacinis,false)
grp.checkwrite (sil_siurb_onoff, true)
grp.checkwrite (dv1_voztuvas,false)
grp.checkwrite (dv2_voztuvas,true)
grp.checkwrite (trieigio_PID_enabled_disabled, true)
logEventWithAddress("Valve control - Heat pump HEATING", adresas)
--*********************Valve control - Heat pump cooling**************************************
if not grp.getvalue(thermostat_Heating_Cooling)
then
grp.checkwrite (sil_siurb_cool_heat, false)
os.sleep(1)
grp.checkwrite (srb1_cirkuliacinis,false) -- SRB1 OFF
logEventWithAddress("Valve control - Heat pump COOLING", adresas)
