[OLD] LogicMachine firmware 2023.06
#21
(27.12.2023, 13:56)Daniel Wrote: Post the links where from you downloaded the packages.
It installed after several restart. And we didn't do it anything special . Just restart several times Sad
Here is the link.
https://dl.openrb.com/lm-23-imx6/pkg
#22
I just tried on firmware 20230612 on LM5 Lite and works just fine. Did you try re-downloading the package and signature again? Drop a screenshot of the error.
Hello
grp.update send updated value to KNX bus when knx connection mode is IP routing
HW: LM5 Lite (i.MX6)
SW: 20230607
This is by design. It won't happen if you use virtual group address range. You can also enable "Filter local update telegrams" in "Local > IP filter" and adjust the filtering table accordingly.
#25
(16.01.2024, 08:29)admin Wrote: This is by design. It won't happen if you use virtual group address range. You can also enable "Filter local update telegrams" in "Local > IP filter" and adjust the filtering table accordingly.
I need to update GA value which can be read later from bus. I can`t use virtual address or filter (((
Is there any way to update object value without sending to any interface?
Can I use db:update('objects', { datahex = 1 }, { id = obj.id }) ? Will web UI be updated values automatically after that?
#26
You will have to manually reload UI to see the new value if you update it via a DB query.
