TCP over SSL
Question
anybody had any success creating an SSL server listener in LUA ?
There seems to be an issue with the server socket not being able to receive() from the client. Sending from server to client however, works just fine.
Note that I tried using it in a copas handler first, and then as a simple standalone luasec handler (running on my machine, not in LM)
Simple test code looks like this:
local socket = require("socket")
local ssl    = require("ssl")
local params = {
   mode = "server",
   protocol = "tlsv1_2",
   key = "C:\\ .... \\serverkey.pem",
   certificate  = "C:\\ .... \\server.pem",
   cafile = "C:\\ .... \\root.pem",
   verify = {"peer", "fail_if_no_peer_cert"},
   options = "all",
local server = socket.tcp()
local ctx = assert(ssl.newcontext(params))
server:setoption('reuseaddr', true)
assert( server:bind("10.20.2.92", 2000) )
server:listen()
local peer = server:accept()
peer = assert( ssl.wrap(peer, ctx) )
peer:dohandshake()
data = peer:receive()  -- <--- HANGS !
print("receieved: " .. data)
peer:send("Pong!\n")
peer:close()
SSL server is not yet supported, we'll try to prepare an update this week though Smile
(01.11.2016, 09:30)admin Wrote: SSL server is not yet supported, we'll try to prepare an update this week though Smile
Ok ! I assume it will be via luasec ?
I got my code working though, turned out to be a hickup on the client side.
Hi Admin,
Is there any update on running an ssl server on the lm? Can this be done without a cert?
Thanks,
Roger
It's possible, but you cannot run it without a certificate. You can reuse web-server's self-signed certificate though. Here's a short example:
if not tcpserver then
  require('copas')
  sslparams = {
    mode = 'server',
    protocol = 'tlsv12',
    key = '/etc/nginx_sha256.key',
    certificate = '/etc/nginx_sha256.crt',
    options = 'all',
  -- connection handler
  function connhandler(sock)
    local ip, port = sock:getpeername()
    sock = copas.wrap(sock, sslparams)
    sock:dohandshake()
    alert('[server] connection from %s:%d', ip, port)
    -- main reader loop
    while true do
      -- wait for single line of data (until \n, \r is ignored)
      local data, err = copas.receive(sock, '*l')
      -- error while receiving
      if err then
        alert('[server] closed connection from %s:%d', ip, port)
        return
      -- handle data frame
      if data == 'HELLO' then
        sock:send('HELLO TO YOU\r\n')
        sock:close()
  -- bind to port 12345
  tcpserver = socket.bind('*', 12345)
  -- error while binding, try again later
    os.sleep(5)
    error('[server] error: cannot bind')
  -- set server connection handler
  copas.addserver(tcpserver, connhandler)
copas.step(1)
Thanks Admin, that works..
Hi Admin,
A couple of questions,
Will this server support multiple clients? I added a basic authentication, that just sets a global variable on connecting and closes the connection if the password is incorrect.
The data received is passed another function parseC. Now I need to be able to respond back to the connected client where I declared a global function in this handler. Is this the right way to do this?
      if data then
       if(first==true)then
          if(data ~='mypassword')then
            first=false
            sock:close()
        Sclient= function (param)
          sock:send(param)
        local fd,prtd = pcall(parseC,data)
        if(fd==false)then
          alert("[elk-client] Error with parsemsg %s ",prtd)
Thanks,
Roger
Yes, it supports multiple clients.
See this example on how to pass data to all connected clients:
http://openrb.com/example-lm2-as-tcp-ser...-requests/
You can pass any number of arguments via pcall, you can pass both data and socket if you want to send a reply to a specific client.
