[OLD] LogicMachine firmware 2017.06
#41
In also in trend logs the zoom in-out and data button does not work
George
#42
(24.11.2017, 07:50)gtsamis Wrote: Hi,
George
Hi, what device (iPad, Laptop) are you using? trends does not work correctly on our HP laptops with sensor display. when we try to zoom with mouse - it does not work, but it works with fingers and sensor display
#43
George
It's a toshiba satelite laptop, but never had the same problem before, also tried with several browsers and still didn't work. On my desktop pc works fine.
#44
Thanks for info, we are looking into trends issue with touch-enabled laptops.
#45
@Admin, For the new update, think of this issue.
[Image: attachment.php?aid=694]
Jean-Marc
#46
Can you upload your backup to https://wetransfer.com/ and send a link via PM?
#47
(30.11.2017, 07:29)admin Wrote: Can you upload your backup to https://wetransfer.com/ and send a link via PM?
The backup link is in your PM .
Jean-Marc
#48
Thanks, we'll fix this in next release.
#49
The "Displaying objects ..." message is totally crazy
https://www.dropbox.com/s/3fgsxf7izsh3ye...6.png?dl=0
#50
(30.11.2017, 11:04)Thomas Wrote: The "Displaying objects ..." message is totally crazy
What is crazy here? the object filter 100/100/100 ?
This https://www.dropbox.com/s/7fpzo92bnw7xex...2.png?dl=0
#52
What's crazy is using a address filter 100/100/100 as this is not a valid range (:
#53
(30.11.2017, 13:13)Erwin van der Zwart Wrote: What's crazy is using a address filter 100/100/100 as this is not a valid range (:
OK. I tried to explaint this issue on obviously non existing object. In this case I'd expected "Displaying objects none" etc. because everything had been of course filtered out.
Here you can see the same problem on actually existing filtered one object.
Display objects 1-16 of 16? 16 what? https://www.dropbox.com/s/971q1fttn2idqp...4.png?dl=0
And as a bonus the number 16 is changing every second. I tried F5, Sync project data, Refresh. Nothing helped.
#54
@Admin, Other issue, when we use a group adress filter only one page is shown even if there is several hundred objects to display.
You can verify with the backup that I have send you to PM.
Jean-Marc
#55
I do not know if it was already indicated, "Export All Logs" stop has the first line which contains a boolean data type.
Jean-Marc
#56
Thanks, we are already aware of this bug Smile
#57
Hi Admin
I Have a LM5 Power DM1, wich file should I use for uppgrade and where can I see my current version.
There are no info in the bottom left corner as many talk about and in packages I see
eibd 20170119
basefile 20170112-r47803
and many that starts with 2016.
Have tried using lm5m3-20170620 and same version 3ex but when trying to uppgrade the wheel spinns forever or if I hit update page its just as when I started. Have tryed to run th "script" in you recomendations once but nothing changes, perhaps I am running the script wrong!? Am not good with programming.
Sincerley
/A
#58
You can find you current firmware version in LogicMachine main interface > bottom left corner. For your device you need LM5M3EX firmware.
#59
You can re-flash the card fallowing this
http://openrb.com/reflash-logicmachine3-...-software/
I am struggling with updating, the LM says "Cannot upgrade, firmware image file is invalid".
The reason i want to upgrade the firmware is that the device wont import new addresses from ETS via a ETS export anymore, I need to to that manually (dont know why).
I have tried running the script for updating, but not sure if I am doing it the right way since nothing changes.
