Export CSV
I made some tests, and I notice it works fine when export_all = true, when I put it false then happens what I wrote upside.
So I think is just the filtering function not properly working.
here is the script:
--**************************************************************************-- --** Email trendlog data as CSV attachment created by Erwin van der Zwart **-- --************ For HL from FW 1.5 and SL from FW 1.2 with NGINX ************-- --**************************************************************************-- --*************************** Start of parameters **************************-- -- Version 1.1 *************************************************************-- --Set export mode (selected trend(s) or all trends) export_all = false --Set trend names if not all trends need to be exported (only used when export_all = false) trendnames = {     "Potenza Attiva PT",       "Forno",       "Microonde",       "Piano Lavoro",     "Prese Stireria",     "Lavastoviglie",     "Lavatrice",     "Asciugatrice",     "Lavastoviglie 2",       "Carico 9", } --**************************************************************************-- --**************************** End of parameters ***************************-- --**************************************************************************-- --****************** DON'T CHANGE ANYTHING UNDER THIS LINE *****************-- --**************************************************************************-- require('trends') -- Get all trend names from DB trends_table = db:getall('SELECT name FROM trends ORDER BY name DESC') -- Check if all trends or selection neeed to be exported if export_all == false then   tmp = {}   for _, t in ipairs(trends_table) do     for _, name in ipairs(trendnames) do       if name == t.name then         tmp[ #tmp + 1 ] = t       end     end   end   trends_table = tmp end -- Check if the is at least 1 trend to be exported if #trends_table < 1 then   log("Nessun Trend disponibile, impossibile esportare")   return end -- csv buffer buffer = {} -- Add to buffer table.insert(buffer, '"Questo file contiene i dati in formato CSV di ' .. #trends_table .. ' trend(s), creato automaticamente in data: ' .. os.date("%d-%m-%y alle %H:%M") .. '"') -- Add empty line table.insert(buffer, '""') -- Loop through trends_table for _, trend_names in ipairs(trends_table) do   -- Grab trend name from DB table   trend_name = trend_names.name   if string.sub(trend_name, -1) ~= '_' then       -- Add to buffer   table.insert(buffer, '"START TREND N.' .. _ .. '     <<< ' .. trend_name .. ' >>>"')   -- Add empty line   table.insert(buffer, '""')     -- Get current timestamp timestamp = os.time() enddate = os.date('*t', timestamp)   startdate =  os.date('*t', (timestamp - 60*60*24)) -- 1 day dates = {} dates['start'] = startdate dates['end'] = enddate       -- Set resolution to dayly data   resolution = 60*15 -- 15 min     -- Get last month for data by each days in this month   trenddatamonth = trends.fetch(trend_name, dates, resolution)     -- Get last month total avarage data   trenddatamonthavg = trends.fetchone(trend_name, dates, resolution)   -- Add header   table.insert(buffer, '"Data","Ora","Valore Medio Giornaliero"')   for _, row in ipairs(trenddatamonth) do     stamp = dates['start'].year .. '-' .. dates['start'].month .. '-' .. string.format("%02d", _)         local y, m, d = stamp:match("(%d+)%-(%d+)%-(%d+)")         local t = { year = y, month = m, day = d}         n15 = tonumber (string.format("%02d", _))*60*15         modulo = n15*15         hours1 = string.format("%02.f", math.floor(n15/3600));     mins1 = string.format("%02.f", math.floor(n15/60 - (hours1*60)));     Ora = hours1..":"..mins1                 -- format csv row    csv = string.format('%q,%q,%q', string.format("%02d", dates['start'].day) .. "-" .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year, Ora, row)     -- add to buffer     table.insert(buffer, csv)   end   -- Add empty linestring.format("%02d", _)   table.insert(buffer, '""')   -- Add header   table.insert(buffer, '"END TREND ' .. _ .. '     <<< ' .. trend_name .. ' >>>"')   -- Add empty line   table.insert(buffer, '""')   end end --Create table to include mail settings local settings = {     from = from,     rcpt = to,     user = user,     password = password,     server = 'smtp.gmail.com',     port = 465,     secure = 'sslv23', } --Create attachment inside FTP server src = 'Trend Export '.. os.date('%Y-%m-%d') .. '.csv' dst = '/home/ftp/' .. src io.writefile(dst, buffer) -- read csv report file data1 = io.readfile(dst) -- send file as report.csv with text/csv mime type soggetto = 'XXXXXX: invio TRENDS giornalieri' testo = 'Si allega file CSV.' res, err = mailattach('giuseppe.dimaria@komponext.it', soggetto, testo, src, data1, 'text/csv') log(res, err) --Delete created backup file from ftp folder inside HL os.remove(dst)
Export CSV - by gdimaria - 25.11.2020, 12:06
RE: Export CSV - by admin - 25.11.2020, 13:15
RE: Export CSV - by gdimaria - 26.11.2020, 17:27
RE: Export CSV - by gdimaria - 26.11.2020, 14:31
RE: Export CSV - by admin - 27.11.2020, 08:20
RE: Export CSV - by gdimaria - 27.11.2020, 08:55
RE: Export CSV - by Domoticatorino - 11.12.2020, 15:13
