Delay for DALI !
#24
Hello, in the Dali controls, having a minimum physical regulation value, the regulation bar is always at very high values, since I have a status object associated with it.
To fix this, I have created a script to fool my client.
In this case, I have a ballast with a minimum physical value of 161 which is 63%. This tells us that we have 37% regulation.
1- I made this script so that my control object, when I send 1%, actually send the value 63% and from there the final result would increase until it reaches 100%.
2- I have created another status script, which does the same calculation but in reverse.
My problem here is that the calculations are not exactly identical in one script and the other, with a minimal difference due to the decimals.
Surely there is another way to achieve this ... can you help me?
Control object% visu (1/3/9)
Status object% visu (1/4/9)
Ballast control object (1/5/9)
Ballast Status Object (1/6/9)
Control script (1/3/9)
--Minimum physical value of ballast VFM = 63 --Regulation output object VReg= '1/5/9' ------------------------------------ value = event.getvalue() OP1 = (100-VFM)/100 OP2 = (value*OP1)+VFM if value==0 then   grp.write(VReg, 0) elseif value>=1 then   grp.write(VReg, OP2) end
State script (1/6/9)
--Minimum physical value of ballast VFM = 63 --Regulation output object VReg= '1/4/9' ------------------------------------ value = event.getvalue() OP1 = (100-VFM)/100 OP2 = (value-VFM)/OP1 if value == VFM then   grp.write(VReg, 1) elseif value ~= VFM then   grp.write(VReg, OP2) end
Delay for DALI ! - by phongvucba - 01.06.2020, 06:31
RE: Delay for DALI ! - by admin - 01.06.2020, 06:52
RE: Delay for DALI ! - by phongvucba - 02.06.2020, 03:55
RE: Delay for DALI ! - by admin - 02.06.2020, 07:44
RE: Delay for DALI ! - by phongvucba - 02.06.2020, 08:06
RE: Delay for DALI ! - by admin - 02.06.2020, 11:28
RE: Delay for DALI ! - by phongvucba - 02.06.2020, 16:08
RE: Delay for DALI ! - by phongvucba - 03.06.2020, 03:32
RE: Delay for DALI ! - by admin - 03.06.2020, 06:11
RE: Delay for DALI ! - by davidchispas - 04.01.2021, 09:59
RE: Delay for DALI ! - by phongvucba - 14.11.2020, 07:17
RE: Delay for DALI ! - by admin - 14.11.2020, 08:05
RE: Delay for DALI ! - by phongvucba - 14.11.2020, 09:15
RE: Delay for DALI ! - by Daniel - 16.11.2020, 08:40
RE: Delay for DALI ! - by phongvucba - 01.12.2020, 11:27
RE: Delay for DALI ! - by davidchispas - 24.11.2020, 10:46
RE: Delay for DALI ! - by admin - 24.11.2020, 10:48
RE: Delay for DALI ! - by admin - 24.11.2020, 10:58
RE: Delay for DALI ! - by davidchispas - 24.11.2020, 11:12
RE: Delay for DALI ! - by Daniel - 01.12.2020, 11:30
RE: Delay for DALI ! - by admin - 04.01.2021, 10:58
RE: Delay for DALI ! - by davidchispas - 05.01.2021, 09:34
RE: Delay for DALI ! - by admin - 05.01.2021, 09:36
RE: Delay for DALI ! - by davidchispas - 13.01.2021, 10:47
RE: Delay for DALI ! - by Daniel - 13.01.2021, 11:00
