DMX Speed
I´m working with DMX lighting of a bridge and I have some problems with the final solution.
They want to do some animations with lights and speedo of DMX not work fine, I don´t know if the problem is Logic Machine Script or DMX lights.
An example:
I have 52 RGBW lights and I want to write  a color individually in each light.
for i = 1, 52, 1 do     grp.update(dir[i], color)     os.sleep(time) end
It i put 1 in time, it work perfectly, but with 500ms, it write in 2 lights at once,with 250ms, it write in 4 lights at once....
I think there is a limitation in the communication of 1 second.
Default params:
local defaults = {   -- storage key   skey = 'dmx_line_1',   -- RS-485 port   port = '/dev/RS485-2',   -- number of calls per second   resolution = 20,    -- default 20   -- total number of channels to use   channels = 256,   -- transition time in seconds, does not include DMX transfer time   transition = 1, }
I tried to change resolution in params to 200 but doesn´t work, it works worse.
Any ideas?
Thanks!
DMX Speed - by DGrandes - 04.02.2022, 10:11
RE: DMX Speed - by admin - 04.02.2022, 10:14
RE: DMX Speed - by Punchito - 13.11.2023, 14:00
RE: DMX Speed - by Daniel - 13.11.2023, 15:48
RE: DMX Speed - by Punchito - 14.11.2023, 07:04
RE: DMX Speed - by admin - 14.11.2023, 08:39
