[OLD] LogicMachine firmware 2022 RC1
(14.12.2022, 15:49)Daniel Wrote: The event script runs each time when you trigger it. The script can run for some
time especially when you add a delay. The same script may run several times if you
trigger it in quick succession.
The First instance does not start a new script (PID) if it is already running.
The Last instance stops all running scripts and PIDs as these are the processes
running internally and it runs only the last one triggered. This option is commonly
used when users save the current PID into storage. If the next one is triggered then
it stops the running PID
Perfect, very useful. Thanks!
Just a question more: what if I run a first instance or last instance script in a LM with an older firmware?
Peppe
RE: [PRE-RELEASE] LogicMachine firmware 2022 RC1 - by gdimaria - 14.12.2022, 15:56
