18.09.2020, 08:12
You are probably using DALI RGBW not 4-byte RGBW data type
How to use new datatype RGB-W
18.09.2020, 08:12
18.09.2020, 08:34
22.09.2020, 13:20
It's very strange: when I pickup a preseted colour (I preseted 6) everything is working fine. If I choose a color from RGB Palette, it returns a wrong color.
Can you help me? Here are my RGB Scripts: --- mergeRGBW ---- if event.sender == 'se' then return end IndRichiesta = event.dst len = string.len(IndRichiesta) suffisso = string.sub(IndRichiesta, -(len-5)) --log(IndRichiesta) R = grp.getvalue('11/4/'..suffisso) G = grp.getvalue('12/4/'..suffisso) B = grp.getvalue('13/4/'..suffisso) W = grp.getvalue('10/4/'..suffisso) RGBW = R * 0x1000000 + G * 0x10000 + B * 0x100 + W grp.checkupdate('40/4/'..suffisso, RGBW) --- icon address ------- splitRGBW ----- if event.sender == 'se' then return end value = event.getvalue() ---- from 32/1/20 icon address -- Split R = bit.rshift(bit.band(value,0xff000000),24) G = bit.rshift(bit.band(value,0x00ff0000),16) B = bit.rshift(bit.band(value,0x0000ff00),8) W = bit.band(value,0x000000ff) IndRichiesta = event.dst len = string.len(IndRichiesta) suffisso = string.sub(IndRichiesta, -(len-5)) grp.checkwrite('11/3/'..suffisso, R) grp.checkwrite('12/3/'..suffisso, G) grp.checkwrite('13/3/'..suffisso, B) grp.checkwrite('10/3/'..suffisso, W) ------------------------------- Thanks, Peppe
22.09.2020, 13:52
The script works fine and it doesn't matter where I select color. Clear browser cache.
22.09.2020, 15:13
22.09.2020, 15:20
Whit hit we can't help. We only send the telegram with specific values. This is mostly to your lights.
23.09.2020, 07:53
(22.09.2020, 15:20)Daniel. Wrote: Whit hit we can't help. We only send the telegram with specific values. This is mostly to your lights. Ok, but it seems very strange to me ALL lights are defective... I will investigate. by the way, what can you explain me the exactly function indicated by the red arrow? Could it get involved? Thanks Peppe
23.09.2020, 07:55
I'm not saying that lights are defective. They do not mix the color as you would want to.
23.09.2020, 08:15
(23.09.2020, 07:55)Daniel. Wrote: I'm not saying that lights are defective. They do not mix the color as you would want to.ok but if I send the value by ETS it works fine. Please, explain me the fuction "send after each color pick". Now I will try to use RGB instead of RGBW, just to check if the 3 colour mixture works....
23.09.2020, 08:18
Compare the values we send with the ones in ETS.
It just send telegram each time you select a color.
24.09.2020, 08:38
(23.09.2020, 08:18)Daniel. Wrote: Compare the values we send with the ones in ETS. Yes, the values are the same. I noticed the if I choose a color from palette (i.e. red) the light turns in red for milliseconds... then become white... or very clear.. or another color. But we are very on trouble now... ![]()
24.09.2020, 08:44
Maybe the light needs the values to be send in special order? In your script you send white as last. Maybe your dali gateway supports the RGBW object? Might be better to use this one instead of 4x 1 byte.
25.09.2020, 07:33
Today I will try to invert the order of sending, I will let you know.
I don't know if my DALI GATEWAY supports RGBW object... anyway, I think I should use a different conversion script, isn't?
22.12.2024, 20:44
hi, where do I find this widget.
23.12.2024, 08:47
Just use this object on visualisation and click on it.
23.12.2024, 10:02
« Next Oldest | Next Newest »
