as you know on example section there is script to realise 30 PID Thermostats. As you can see PID is 1 byte but I should manage the histeresy in 1 bit. 2 point valve on/off.
12.09.2016, 15:03 (This post was last modified: 12.09.2016, 15:06 by Erwin van der Zwart.)
Hi Claudio,
You can put a event based script on the 1 byte output and write a bit output to another object
1234567891011121314
output = event.getvalue()
ifoutput > 0then-- Get value of object to avoid write true on each 1-100 valuebitvalue = grp.getvalue('yourbitobject')
ifbitvalue == falsethengrp.write('yourbitobject', true)
endelse-- Get value of object to avoid write false on each 0 valuebitvalue = grp.getvalue('yourbitobject')
ifbitvalue == truethengrp.write('yourbitobject', false)
endend
Maybe the solution is the PWM controller? For example when your value is 50% and time T is e.g. 1hour your valve will be switched on for 30minutes and switched off for 30minutes. It will be better for the relay because you will have less switching.
07.10.2018, 17:28 (This post was last modified: 07.10.2018, 17:33 by Bobby.)
I have an on/off output, and this works ok. But is it possible to get the output to work like, with 10% gain, it will have 1 min on, and 9 min off. with 60% gain, 6 min on, and 4 min off?
i hope you understand what im meaning..
Today its like attached picture.
But the water haeating system will then have a warm floor when on, and cold when off. is it possible to have the thermostat work in cycles?
Use this script (resident, sleep time = 5 seconds) to convert 0..100% value to slow PWM (proportional on/off). Change input/output objects and period time as needed.
I cannot get any output for 1 byte scaled object. it shows 0% even if the setpoint is 5 degrees higher than current value.
if i change the scaled object to 50%, the output will change from '0' to '1'. so the last script should be ok.
please take a look at the attached pictures, and tell me where i went wrong...
You need to change the PID user library back to the original version and do full resident script restart via disable/enable, otherwise new library code won't load.
09.10.2018, 08:39 (This post was last modified: 09.10.2018, 08:40 by Bobby.)
Yeay. did a backup, rebooted. When started up, 16 of my OV - PID adresses was gone. run the backup, still missing. what happened? is this a fault in LM? all the values was 0%. do they need to be changed for remembering?
Actually, several group addresses, who i have changed name on, is missing???
(09.10.2018, 11:23)admin Wrote: Looks like microSD card in your LM became read-only. You need to replace it with a new one an run recovery procedure. See more info here: http://openrb.com/reflash-logicmachine3-...-software/
