Yes that is all correct, i don’t think anyone has the new HW for spaceLYnk already as there where still a few on stock, the homeLYnk hardware is already changed to Wiser for KNX (W4K).
28.10.2017, 08:47 (This post was last modified: 28.10.2017, 08:49 by Habib.)
What it's exact meaning the homelynk is changed to Wiser. It's a complete Hardware Base changed and is not compatible to spacelynk anymore? Or it's only the naming which has changed?
I need this info, because we sell a lot of SL and HL's.
28.10.2017, 11:04 (This post was last modified: 28.10.2017, 11:07 by Erwin van der Zwart.)
Yes HL and SL got both the same HW (CPU) upgrade, so all keeps compatible as it was.
In the upcomming months we are going to launch our new platform for residential ‘Wiser’ a 100% wireless system based on Zigbee and Bluetooth for Light, Heat, Energy and Door communication.
homeLYnk is now renamed to Wiser for KNX (W4K) and will become fully integratable with the new Wiser platform. For now it has no changes in the FW for Wiser because Wiser HW is not available yet but upcomming FW will get extra features to support Wiser Zigbee and BLE.
Our new Wiser will be showed on L&B 2018, Merten (by Scheider Electric) already has the Wiser Light BLE switches on the market with very cool features you can set into the switch like schedulers, timers etc. You can retrofit your house to latest automation in a few hours without re-wiring. Add W4K and your wireless Wiser installation is fully compatible with KNX, Modbus, BACnet, IP and IoT.
28.11.2017, 16:31 (This post was last modified: 28.11.2017, 16:34 by Erwin van der Zwart.)
Under System -> Status -> System Status you can see the CPU model, this will tell HW1 or HW2 version. (ARM9 = HW1), MAC can be found under System -> Network -> Interfaces.
HW 3.0 has 2 x faster CPU(900MHz), 2xmore RAM(256MB) and it has SPI flash to keep the data safe forever. HW3.1 to all that also has SCL industrial SD card.
HW1.X = i.MX28 - 456MHz
HW2.X = i.MX6 - 500MHz - 3X faster then HW1.X
HW3.X = i.MX6 -900MHz - 6X faster than HW1.X, 2X faster than HW 2.0
The speed multiplications are not always correct as it depend of what type of operation but on average it should be like that.
(08.03.2019, 17:28)FatMax Wrote: Late September 2018, purchased and installed by Schneider Electric.
That is in did on a edge when we started to supply. There is easy way to check if it is 2.0 or 3.0. In Configuration next to CPU/IO and RAM there should be also info about DISK. If you have disk info then it is 3.0 if not then 2.0. This is info about space left on SPI flash.
