Script for Open Window - thermostat protection mode
Good afternoon
I have to make a script so that when the windows of the house are opened the thermostat is put in protection mode for this I have
1/1/1 heating mode true
1/1/2 window salon 1 or 1/1/3 window salon 2 o .....
then 1/1/8 protection mode thermostat salon true
also when also the 1/1/1 heating mode true
1/2/1 kitchen window 1 or 1/2/2 kitchen window 2 o ...
1/2/8 cooking thermostat protection mode true
I have an idea of how to do it but I can not make it work
Can you help me?
Here is a sample of a scheduler + twilight + overrule button logic so you can see how to build it.
The inputs 32/x/x are tagged and the script is event based attached to the same tag.
klok = '32/1/1' schemer = '32/1/2' overbrug = '32/1/3' uitgang = '1/0/52' waarde_klok = grp.getvalue(klok) waarde_schemer = grp.getvalue(schemer) waarde_overbrug = grp.getvalue(overbrug) waarde_uitgang = grp.getvalue(uitgang) if waarde_overbrug == true then  if waarde_uitgang == false then    grp.write(uitgang, true)  end else  if waarde_klok == true and waarde_schemer == true then    if waarde_uitgang == false then      grp.write(uitgang, true)    end  else    if waarde_uitgang == true then      grp.write(uitgang, false)    end  end end
(09.06.2019, 22:09)Erwin van der Zwart Wrote: Hi,
 Good morning Erwin:
  I appreciate very much the answer, but it's not exactly what I want to do, maybe what I want to do is easier, but it's hard for me
  What I want to do is that when the heating of the house is in "heating" mode 1/1/1 "true"
and there will be a Room Window 1/1/2 (window 1) or Window 2 of room 1/1/3 (window 2) or window "n" of the room
So
The address 1/1/8 thermostat protection mode is = true
but also in the rest of the rooms the same
  If heating mode 1/1/1 is true
and opens Window 1 of the room (1/2/1) or window 2 of the room (1/2/2) or window n of the room ...
so
the direction 1/2/8 protection mode of the thermostat is = true
  Josema
Yes i know, Normally we don't create scripts on request (simply not possible to do that for everyone) and we give samples how to achieve something..
Here is the  script you need:
heating_mode = grp.getvalue('1/1/1') protection_mode = '1/1/8' if heating_mode == true then   windows = grp.tag('Window')   windowopen = false   for _, window in ipairs(windows) do     if window.value == true then       windowopen = true       break     end   end    if windowopen then     grp.checkwrite(protection_mode, true)   else     grp.checkwrite(protection_mode, false)   end else   grp.checkwrite(protection_mode, false) end
Tag your objects /script like this:
You can do this the same for another floor with second script and different (unique) TAG's.
Hello Erwin
Thank you very much for the Script, I am very grateful to you, this script is an event script or a resident script,
I have a doubt because I have 2 thermostats to change to protection mode depending on the window that opens in the same room, so I have doubts.
Thanks again
Josema
Just like the image shows the script is attached to a TAG (in this case "Heating") so event based.
All input objects are given this TAG "Heating" so if any window or heating is changing state, the scripts executes the logic. The windows are also given the TAG "Window" so the script can grab them all and check if any window is open. The output (protection object) should not have any TAG. (otherwise you create a permanent loop)
You can do this twice, One script for thermostat 1 and one script for thermostat 2. Change the TAG's to Heating1 and Heating2 and Window1 and Window2 and you have twice this logic. Make sure to change the line grp.tag('Window') to grp.tag('Window1') and in the other script grp.tag('Window2') and change the grp adresses in both scripts to the correct ones. (1/1/1 and 1/1/8)
Hi , Erwin
I see that I have a lot to learn
Thank you
Josema
