Threads: 43
New FW here:
https://forum.logicmachine.net/showthread.php?tid=2710
Changelog:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188
2018.05.16
modbus -
fix multiple read for coils /
discrete inputs
modbus -
fix handling of profiles where read_count is smaller than data type width
modbus -
separate modbus error logs from scripting error logs
touch visualization -
add home /
logout buttons
2018.05.23
object logs -
fix source address display ,
add sender field
2018.06.05
fix storage server not starting up when storage database is corrupt
2018.06.13
fix scripting category filter scroll jumping due to reload
2018.07.12
allow spaces in host name
fix internal limit of 8 characters for ftp passwords
enocean -
change only active button state for "Rocker Switch, 1 Rocker (separate)" profile
2018.07.13
add current ip display and static dns settings to ppp /
3g
2018.07.20
allow "@" and "." in user login name
2018.07.27
dali -
add 2 /
3 byte raw telegram support
improve shutdown procedure
2018.07.31
modbus -
add float64 /
double support
2018.08.02
fix rgb picker color selection when control is scaled via CSS
2018.08.20
allow usage of 4 -
bit objects as scene triggers
2018.08.28
change grp.create duplicate name search procedure to ignore case
2018.09.06
dali -
fix broken addressing after raw command has been implemented
2018.09.12
luaencdec library -
add sha384 /
sha512 hash /
hmac calculation
sort widgets /
layouts by name instead of creation order
2018.09.18
lm5 rio -
fix edge case with object value update when enabling input mode for port that is already in active state
2018.09.21
lmwall -
fix sensor values not being displayed
fix checkwrite /
checkupdate always writing a value when passing non-boolean value to a boolean object
2018.09.28
modbus -
remove unused partial xml profile support
2018.10.10
increase maximum user login size from 20 to 50 characters
2018.10.22
increase maximum number of active connections from about 50 to 200
2018.11.16
fix tag event scripts not being executed until saved again when tag is then assigned to a new object
fix knx /
ip rx telegram counter
2018.11.28
dali -
add partial dt8 command support to internal dali library
2018.11.29
add forced https options -
either redirect from http to https or http (
port 80 )
disabled completely
2018.12.05
luasocket -
add "*r" receive pattern -
for lines ending with "\r" (
"\n" is ignored )
2018.12.14
add additional garbage collection steps to resident scripts to prevent open file descriptor limit issues
2018.12.21
improve trends deletion /
resize procedure to flush data to disk immediately
1 -
wire -
allow seting send delta to 0 (
always send new value )
2019.01.10
dali -
add Rainbow /
Ecodim DALI Lux commands
2019.01.23
dali -
add Rainbow /
Ecodim DALI Combisence commands
2019.01.25
modbus -
fix datatype display in mapping window when object datatype is different from modbus datatype
2019.02.19
modbus -
add "float" datatype alias for "float32"
2019.02.20
modbus -
add persistent connection mode for TCP devices
2019.02.21
apps -
add periodical app update check
2019.03.04
visualization -
fix incorrect element size display
2019.03.11
visualization -
fix alignment issue between labels and object value text in "value" mode
2019.03.13
schedulers -
add multiple scheduler display option for direct link view
2019.03.19
bacnet -
fix overridden flag behaviour
2019.04.03
bacnet -
fix scale /
angle data type maximum value handling ,
fix 1 byte ASCII character data type
fix no value display for objects after custom values have been deleted via mass edit
2019.04.11
lm5ex -
fix current measurement incorrect value display when value is negative
2019.05.08
luasocket -
add "*c" (
custom )
receive pattern :
second argument is ending character (
defaults to \
n )
third argument character to skip (
defaults to \
0 )
2019.05.21
add quotes around string table keys in log ()
function ,
otherwise there 's no visual difference between numeric and string keys
2019.05.31
visualization -
add remote url option to camera element
2019.06.06
ftp -
add forced secure (
FTPS )
mode
vis. graphics -
add search
scenes -
add optional status object
object logs -
allow wildcard (*)
search in object name
system config -
add system configuration backup /
restore
2019.06.14
schedulers -
add on /
off object for scheduler control
visualization -
add background color setting for pop-up control elements (
sliders ,
text input ,
etc )
add drag /
drop sort via separate window to trends ,
schedulers ,
scene sequence and visualization structure
2019.06.28
add brute force protection for HTTP /
FTP
2019.07.08
modbus -
fix object tag /
comment being cleared when mapping an existing object to a modbus register /
coil
2019.08.02
add LM5RDC model
2019.08.05
luasocket -
set default TLS version to 1.2 for HTTPS requests
2019.08.12
improve LuaSocket HTTP requests :
1. HTTPS is now handled by socket.http.request ,
ssl.https is not needed for HTTPS anymore
2. Response is returned automatically if no sink is set ,
setting sink is not needed
3. POST body can be set by adding "body" request key
4. POST body can be a table which will is automatically encoded to a string according to x-www-form-urlencoded format
2019.08.13
trends -
show total trend size in MB
2019.08.20
modbus -
fix potential out-of-bounds read in slave mode
2019.08.26
fix typos in documented datatypes
2019.08.28
bacnet client -
add "command" object type support
2019.10.02
modbus -
force send of value_default for remaining objects when polling cycle for a given device hits 3 consecutive errors
2019.10.08
dali -
add partial addressing mode (
only new ballasts without short address )
2019.10.10
luasocket -
add TCP port to HTTP host header for requests to non-standard ports
luasocket -
fix HTTP redirect
2019.10.11
schedulers -
use sub-datatype text for boolean value select options instead of generic on /
off
Threads: 4
31.10.2019, 13:35
(This post was last modified: 31.10.2019, 13:36 by fiLLLip .)
(31.10.2019, 12:44) admin Wrote: /snip
Use "
LM5 Power with extensions" for the DW1?
Threads: 161
Hi Admin, thanks for this good info, could you attach some change log?
Done is better than perfect
Threads: 43
(31.10.2019, 13:35) fiLLLip Wrote: Use "LM5 Power with extensions" for the DW1? Yes, if you go to System Config > System > Upgrade Firmware it will show your device mode.
(31.10.2019, 13:51) buuuudzik Wrote: Hi Admin, thanks for this good info, could you attach some change log?It's posted, have a look
Threads: 43
Will this update be avaliable for the Load Balancer?
Threads: 161
(07.11.2019, 07:42) gtsamis Wrote: Hi,
Will this update be avaliable for the Load Balancer?+1
Threads: 43
Maybe after final release. I cannot promise anything right now as I'm not sure if the only device that we have here is working or not.
Threads: 43
Any comments on RC1?
RC2 is coming in several weeks with several changes/fixes:
bacnet - add optional object units/suffix conversion to BACnet units
schedulers - fix incorrect execution time for sunrise/sunset events during daylight saving chang
dali - fix mode select window height
Threads: 161
I've upgraded recenly LM5 RIO 2. Which packages should I also upgrade to have it fully upgraded? After upgrade e.g. Modbus could not work properly (it is not used on this installation but I want fully upgrade this device)?
Threads: 161
10.11.2019, 05:11
(This post was last modified: 10.11.2019, 05:31 by buuuudzik .)
This is very urgent!!!
After upgrade client told me that buttons connected to LM RIO2 are not working now. How can I solve this issue?
Its LM using only KNX and buttons , no modbus, no other interface.
You have so much versions, every piece is important(I/O, modbus, 1wire etc.) so I think upgrade should be done by LM automatically (including packages). Or at least LM should list in standarized way packages which should be used.
I've attached photo of his LM to simplify recognizing it.
Im attaching also screenshot from packages view
Threads: 43
Since this is a pre-release test version we recommend using it only in your personal installations where you have immediate physical access to the device.
As for packages all firmwares have everything pre-installed depending on what the device has on-board. Extra packages are needed for additional functionality like SNMP or 1-wire via USB on devices without on-board chip etc.
Can you provide remote access to this device that is not working? Have you checked that outputs are working?
Threads: 161
The problem were in scripts not in buttons. I have such configuration:
button => tag => eventbased script => udp => resident script
And resident script didn't receive any command until I saved, disabled, enabled eventbased script.
So please check what is the configuration of startup scripts, and other users please check this in your scripts.
Threads: 43
Thanks for testing. Can you reboot the device and check if the event script is working or not after reboot?
Threads: 161
Yes, I've did reboot and all works fine now.
Does reboot is also one of a step in upgrade process?
Please test such things:
- if after upgrading device with event-based tag scripts they are in idle state,
- or what is the state of resident scripts after reboot?
I had such situation that GA appeared on the bus but probably event-based script not react on a tag becaue probably it was in some idle state. When I've saved, disabled, enabled this script and once again send that command to the bus then resident script logged that it received command.
In this idle state it was not important if the ga appeared from bus, from other device or from Object tab. Both not worked.
Threads: 43
Did you get any entries in Errog Log like file not found or similar?
Threads: 161
No, there was no errors in Error tab.
Threads: 7
I have noticed non working scripts by TAG several times and reported it to the team, this was already in 2.3.0, i think it occurs when adding a TAG to a event based script first and then add the TAG to the object. After dis/enabling the script it starts working, so yes we should check this especially when it also occurs after a upgrade.
Threads: 31
22.11.2019, 18:53
(This post was last modified: 22.11.2019, 18:55 by DGrandes .)
I recently install the new firmare and MQTT don´t works . Just receive but don´t send MQTT..
(with previous version it works fine)
Has something changed?
if not broker then
broker =
'MosquitoBroker'
mqtt_to_object = {
'MyObject' ] =
'command...' ,
object_to_mqtt = {
'MyObject' ] =
'command...' ,
datatypes = {}
grp.sender =
'mq'
require (
'socket' )
for addr ,
_ in pairs (
object_to_mqtt )
do
local obj =
grp.find (
addr )
if obj then
datatypes [
addr ] =
obj.datatype
mclient =
require (
'mosquitto' ).
new ()
mclient.ON_CONNECT =
function ()
if grp.getvalue (
'33/1/116' )
then WriteSendTo (
"David" ,
"MQTT Conectado" )
for topic ,
_ in pairs (
mqtt_to_object )
do
mclient :
subscribe (
topic )
mclient.ON_MESSAGE =
function (
mid ,
topic ,
payload )
local addr =
mqtt_to_object [
topic ]
if addr then
grp.write (
addr ,
payload )
mclient.ON_DISCONNECT =
function (...)
if grp.getvalue (
'33/1/116' )
then WriteSendTo (
"David" ,
"MQTT Desconectado" )
mclientfd =
nil
function mconnect ()
local fd
mclient :
connect (
broker )
fd =
mclient :
socket ()
if fd then
mclientfd =
fd
mconnect ()
function publishvalue (
event )
if event.sender ==
'mq' or not mclientfd then
return
local addr =
event.dst
local dpt =
datatypes [
addr ]
local topic =
object_to_mqtt [
addr ]
if not dpt or not topic then
return
local value =
busdatatype.decode (
event.datahex ,
dpt )
if value ~=
nil then
if type (
value ) ==
'boolean' then
value =
value and 1 or 0
mclient :
publish (
topic ,
tostring (
value ))
lbclient =
require (
'localbus' ).
new (
1 )
lbclient :
sethandler (
'groupwrite' ,
publishvalue )
lbclientfd =
socket.fdmaskset (
lbclient :
getfd (),
'r' )
timer =
require (
'timerfd' ).
new (
5 )
timerfd =
socket.fdmaskset (
timer :
getfd (),
'r' )
if mclientfd then
mclientfdset =
socket.fdmaskset (
mclientfd ,
mclient :
want_write ()
and 'rw' or 'r' )
res ,
lbclientstat ,
timerstat ,
mclientstat =
socket.selectfds (
10 ,
lbclientfd ,
timerfd ,
mclientfdset )
res ,
lbclientstat ,
timerstat =
socket.selectfds (
10 ,
lbclientfd ,
timerfd )
if mclientstat then
if socket.fdmaskread (
mclientstat )
then
mclient :
loop_read ()
if socket.fdmaskwrite (
mclientstat )
then
mclient :
loop_write ()
if lbclientstat then
lbclient :
step ()
if timerstat then
timer :
read ()
if mclientfd then
mclient :
loop_misc ()
mconnect ()
Threads: 43
Add logging to your script:
function (...)
log (
'on_connect' , ...)
local fd
log (
'connect' ,
mclient :
connect (
broker ))
fd =
mclient :
socket ()
if fd then
mclientfd =
fd
Threads: 31
(23.11.2019, 09:19) admin Wrote: Add logging to your script:
function (...)
log (
'on_connect' , ...)
local fd
log (
'connect' ,
mclient :
connect (
broker ))
fd =
mclient :
socket ()
if fd then
mclientfd =
fd
I add log and when I reset Mqtt scritp this is the result:
When I send object to Mqtt don´t log anything.
