Set a value when a widget come up
Hi, as in the Thread subjet I need to set an object's value (unsigned Integer) when a widget pops up.
Can you help me?
Peppe
You can use this example. Set Additional classes to widget-open for the element that opens the widget. #widget-2 is widget element id, change it and group address as needed.
Keep in mind that it won't work when transition animation is enabled.
$(function() {   $('.widget-open').on('vclick', function() {     var el = $('#widget-2');     if (el.is(':visible')) {       grp.write('1/1/1', 123);     }   }); });
There will be widget show/hide events added in RC2 firmware that will work correctly with animation:
$(function() {   $('#widget-2').on('widget-show', function() {     grp.write('1/1/1', true);   });      $('#widget-2').on('widget-hide', function() {     grp.write('1/1/1', false);   }); });
(22.03.2020, 14:34)admin Wrote: You can use this example. Set Additional classes to widget-open for the element that opens the widget. #widget-2 is widget element id, change it and group address as needed.
Ok thanks but... how I can get the actual WIDGET ELEMENT ID?
Open visualization in your browser, open the widget, right click in any empty space inside your widget and select "inspect element". In HTML inspector you will see something like <div id="widget-2"... widget-2 is your widget ID. Make sure that selector in Custom JS has # in the selector before the ID: $('#widget-2');
Ok! Everything is working... thanks!
Peppe
Just to make it perfect: How I can make a widget pop when when some grp address is triggered?
like you made for a plan with the code  below:
$(function(){
  if (typeof objectStore !== 'undefined') {
    var id = Scada.encodeGroupAddress('1/1/2');
    objectStore.addListener(id, function(object, type) {
      if (type == 'value') {
        showPlan(69);
Tnx
Have you seen this?
https://forum.logicmachine.net/showthrea...34#pid1934
(23.03.2020, 11:50)Daniel. Wrote: Have you seen this?
yes... it seems it doesn't work   Sad
There's an easier way to show a widget by simulating a click on the element that opens it. Make sure that your sending script is not attached to the same element otherwise you will get a loop.
Here, when 1/1/1 value is true view is switched to plan 12 and if #widget-2 is not yet shown a click event is triggered on an element with class show-widget
12345678910111213
$(function() {   if (typeof grp == 'object') {     grp.listen('1/1/1', function(obj, state) {       if (state == 'value' && obj.value) {         showPlan(12);         if (!$('#widget-2').is(':visible')) {           $('.show-widget').click();         }       }     });   } });
when I set a pincode to the button object with the class "#widget-x'" javascript doesn't work!
Is there a solution?
This will not work with a pin-code. You'll have to wait for RC2 to use widget events.
