Email sending do not work
Hello There
I'm new to this forum, and also a littel new to scripting in luna.
I have a Schneider HomeLynk with Wiser for KNX on. I'm trying some very simple thinks regarding sending Email. but I seams to have no luck getting ANY mail send what so ever.
I have now mad a new Gmail accound, and on that on enabled "allow acces for less secure apps" and changed nothing else than that on Gmail side
in script I have changed this to my new settings i common functions:
  local settings = {
    from = 'MYEMAIL@gmail.com',
    -- smtp username
    user = 'MYEMAIL@gmail.com',
    -- smtp password
    password = 'MYCODE',
    -- smtp server
    server = 'smtp.gmail.com',
    -- smtp server port
    port = 465,
    secure = 'sslv23',
And in my triggered function i have this:
-- make sure mail settings are set in user function library before using this function
subject = 'There is new mail'
message = 'Med Venlig Hilsen Kastaniely'
mail('TEST@InoDes.dk', subject, message)
But nothing comes to my Emil, how do I debug that? and any good ideas what to do?
Log what the server reply is:
res, err = mail('TEST@InoDes.dk', subject, message)
log(res, err)
(20.08.2020, 09:35)admin Wrote: Log what the server reply is:
log(res, err)
This is the reply, what do that mean?
Postkasse post ind 20.08.2020 11:21:26
* arg: 1
  * nil
* arg: 2
  * string: Try again
Which FW do you have? You need to change secure = 'sslv23', to secure = 'tlsv1_2',
(20.08.2020, 09:38)admin Wrote: Which FW do you have? You need to change secure = 'sslv23', to secure = 'tlsv1_2',
Where do I see FW version?
Lower left corner says Version 2.4.0 in my browser
Left bottom corner of the main UI (Version: 20200720 or similar)
(20.08.2020, 09:42)admin Wrote: Left bottom corner of the main UI (Version: 20200720 or similar)
Look at attached
Now attached :-)
Change secure field in common functions and try again.
(20.08.2020, 09:49)admin Wrote: Change secure field in common functions and try again.
Tried that, no luck
Postkasse post ind 20.08.2020 11:35:13
* arg: 1
  * nil
* arg: 2
  * string: Try again
How do I check if it can se the internet? It sams like 0.dk.pool.ntp.org do not work either (Just seen that the system clock has driftet)
Did you enabled "less secure apps" in your gmail account? If not you will not be able to send mail..
To check your internet you can open the appstore or do a ping from the network tools..
(20.08.2020, 09:54)Erwin van der Zwart Wrote: Hi,
 Yes I did Smile
Check if you have DNS and gateway set correctly in Network interfaces, You can ping google.com form Network utilities in Status
I can from the system ping 8.8.8.8 (Google) and that works..
Replace the whole email function as it sound as you were upgrading an old device and then old libraries are preserved.
-- send an e-mail
  local settings = {
    from = 'example@gmail.com',
    -- smtp username
    user = 'example@gmail.com',
    -- smtp password
    password = 'mypassword',
    -- smtp server
    -- smtp server port
    port = 465,
    -- enable tls, required for gmail smtp
    secure = 'tlsv1_2',
  if type(to) ~= 'table' then
    to = { to }
  for index, email in ipairs(to) do
    to[ index ] = '<' .. tostring(email) .. '>'
  -- fixup from field
  local from = '<' .. tostring(settings.from) .. '>'
  -- message headers and body
    headers = {
      to = table.concat(to, ', '),
      subject = subject,
      ['From'] = from,
      ['Content-type'] = 'text/html; charset=utf-8',
    body = message
  settings.from = from
  settings.rcpt = to
  return smtp.send(settings)
(20.08.2020, 10:04)Daniel. Wrote: Replace the whole email function as it sound as you were upgrading an old device and then old libraries are preserved.
-- send an e-mail
  local settings = {
    -- smtp username
    -- smtp password
    -- smtp server
    -- smtp server port
    port = 465,
    secure = 'tlsv1_2',
    to = { to }
  -- fixup from field
    headers = {
      subject = subject,
      ['From'] = from,
    body = message
  settings.rcpt = to
Copy pasted all ofyours in under common functions (And replaced Email and code with my own)
But still get no Email, and this error:
Postkasse post ind 20.08.2020 12:01:21
* arg: 1
  * nil
* arg: 2
  * string: Try again
Using this code in triggered script
subject = 'Der er kommet post'
res, err = mail('TSA@InoDes.dk', subject, message)
log(res, err)
--mail('TSA@InoDes.dk', subject, message)
POSTevnt(1) -- Kald funktion med event 1 (Post er kommet)
-- send an e-mail
  local settings = {
    -- smtp username
    -- smtp password
    -- smtp server
    -- smtp server port
    port = 465,
    secure = 'tlsv1_2',
    to = { to }
  -- fixup from field
    headers = {
      subject = subject,
      ['From'] = from,
    body = message
  settings.rcpt = to
* arg: 1
  * nil
* arg: 2
  * string: Try again
log(res, err)
-- send an e-mail
  local settings = {
    -- smtp username
    -- smtp password
    -- smtp server
    -- smtp server port
    port = 465,
    secure = 'tlsv1_2',
    to = { to }
  -- fixup from field
    headers = {
      subject = subject,
      ['From'] = from,
    body = message
  settings.rcpt = to
* arg: 1
  * nil
* arg: 2
  * string: Try again
log(res, err)
-- send an e-mail
  local settings = {
    -- smtp username
    -- smtp password
    -- smtp server
    -- smtp server port
    port = 465,
    secure = 'tlsv1_2',
    to = { to }
  -- fixup from field
    headers = {
      subject = subject,
      ['From'] = from,
    body = message
  settings.rcpt = to
* arg: 1
  * nil
* arg: 2
  * string: Try again
log(res, err)
Is there anything else in system, I can check (It has newer been able to send Email, have tryeid many times to get it to work). Any port in my Network (IP) that has to be speciel or anything else on server that can block it?
"Try again" error usually means that DNS resolve failed for some reason. Check that you have valid DNS set in Network > Interfaces > eth0.
(20.08.2020, 10:29)admin Wrote: "Try again" error usually means that DNS resolve failed for some reason. Check that you have valid DNS set in Network > Interfaces > eth0.
The DNS was wrong! :-)!!!!!!!
Now it is working!!
I am trying to send email with above code but not successed. The ping is ok from LM to for example www.google.com. I have enabled less secure apps on the gmail account.
I have tried both of sslv23 and tlsv1_2 for secure. The log as below.
* arg: 1
* nil
* arg: 2
* string: timeout
Can you access our app store from this LM?
(23.11.2020, 09:55)Daniel. Wrote: Can you access our app store from this LM?
Yes, I can.
