Easee EV Charger
Hello, any ideas on how to integrate this?
https://api.easee.cloud/index.html
I've found a Python script on github, is it possible to convert this in any way?
https://github.com/fondberg/pyeasee
Regards..
This is a similar API: https://forum.logicmachine.net/showthread.php?tid=1786
There's a difference in login procedure (GetToken function). You need to set the 'content-type' header to 'application/json' and send username/password as json string:
request_body= json.encode({
  userName = 'aaa',
  password = 'bbb',
Thanks, it works.
What would be the best way if i wanted the connection to the API to stay active, and then run seperate scripts for various commands?
It's not best practise to request new tokens for every command.
Create a scheduled script that will call GetToken() periodically and save the token into storage. All other scripts will use this token to make requests.
Check the expiresIn field that /api/accounts/token returns. It will tell for how many seconds the token is valid. Adjust scheduled script execution period accordingly.
(15.04.2021, 19:56)tomnord Wrote: Thanks, it works.
Did you get your script to work?
Are you willing to share your script and the commands for the Easee charger?
that would be very nice and would save me a lot of time :-)
Works like a charm. I'll post when I have access to my LM again.
(28.01.2022, 16:28)tomnord Wrote: Works like a charm. I'll post when I have access to my LM again.
Hi soo exaited about this!
Will you post it? Or sent it on PM?
-- Load modules
require('json')
require('ssl.https')
require('ltn12')
-- Set credentials for Easee API
ChargerID = storage.get('EaseeAPI_ChargerID')
API_Token = storage.get('EaseeAPI_Token')  --reads API Token from storage, The token is fetched from scheduled script: "Easee_Authenticate"
--log(ChargerID)
function RequestFromEasee(request)
  request_url = 'https://api.easee.cloud/api/' .. request
  local response_body = {}
  local request_body = ""
  local body, code, hdrs, stat = ssl.https.request{
    url = request_url;
    method = "GET";
    headers =
      ["Content-Type"] = "application/json";
      ["Authorization"] = "Bearer " .. API_Token;
    source = ltn12.source.string(request_body);
    sink = ltn12.sink.table(response_body);
  log(code)
  if code == 200 then
    ret = table.concat(response_body)
    ret = json.pdecode(ret)
    return ret
    --API_Token = GetToken() -- request a new token
-- Get products, run once to get charger ID
if ChargerID == nil then
chargers = RequestFromEasee('chargers')
Easee_ChargerID = chargers[1]["id"]
--log(Easee_ChargerID, 'ID') -- Check here for your charger ID
storage.set('EaseeAPI_ChargerID', Easee_ChargerID)
ChargerState = RequestFromEasee('chargers/' .. ChargerID  .. '/state')
log(ChargerState)
currentChargePower = ChargerState["totalPower"]
currentCableRating = ChargerState["cableRating"]
currentMaxPower = ChargerState["outputCurrent"]
chargerOnline = ChargerState["isOnline"]
currentChargeEnergy = ChargerState["sessionEnergy"]
log(currentChargePower, currentCableRating, currentMaxPower, chargerOnline, currentChargeEnergy)
function WriteToEasee(request, request_body)
  local content_length
  if type(request_body) == "string" then
    content_length = #request_body
    request_body = ""
    url = request_url;
    method = "POST";
    headers =
      ["Content-Length"] = content_length;
  log(code)
  if code == 200 then
    return ret
require('json')
require('ltn12')
email ='****************'
password ='*************'
function GetToken()
  request_token_url = 'https://api.easee.cloud/api/accounts/login'
  local request_body = json.encode({
      userName = email,
      password = password,
    url = request_token_url;
    method = "POST";
    headers =
      ["Content-Length"] = #request_body;
  log(code)
  if code == 200 then
    log(ret)
    return ret.accessToken
-- Request token
if not API_Token then
      log(API_Token, 'api_token')
--Store API Token to memory
storage.set('EaseeAPI_Token', API_Token)
Here is a script I use at a client's company to visualize the current charging power at each charging point in their company parking lot. Thank you tomnord for the earlier scrips Smile
-- Load required libraries once
require('json')
require('ltn12')
-- Your configuration
local API_Token = storage.get('EaseeAPI_Token')
-- Define all 8 charging stations with placeholder names, IDs and KNX group addresses
local chargingStations = {
  { name = 'charger 1', id = 'charger 1 id', ga = '55/1/1' },
  { name = 'charger 2', id = 'charger 2 id', ga = '55/1/2' },
  { name = 'charger 3', id = 'charger 3 id', ga = '55/1/3' },
  { name = 'charger 4', id = 'charger 4 id', ga = '55/1/4' },
  { name = 'charger 5', id = 'charger 5 id', ga = '55/1/5' },
  { name = 'charger 6', id = 'charger 6 id', ga = '55/1/6' },
  { name = 'charger 7', id = 'charger 7 id', ga = '55/1/7' },
  { name = 'charger 8', id = 'charger 8 id', ga = '55/1/8' },
-- Function for making a GET request to the Easee API
local function RequestFromEasee(endpoint)
  local url      = 'https://api.easee.cloud/api/' .. endpoint
  local response = {}
  local _, code  = ssl.https.request{
    url    = url,
    method  = "GET",
    headers = {
      ["Content-Type"]  = "application/json",
      ["Authorization"] = "Bearer " .. API_Token,
    sink = ltn12.sink.table(response),
  if code == 200 then
    return json.pdecode(table.concat(response))
    log('Easee API error (' .. endpoint .. '): ' .. tostring(code))
    return nil
-- Parameters for power calculation
local voltage = 230    -- V per phase
local phases  = 3      -- three-phase
local cosFi  = 0.95  -- power factor, adjust if needed
-- Loop over all charging stations
for _, station in ipairs(chargingStations) do
  -- Fetch status
  local state = RequestFromEasee('chargers/' .. station.id .. '/state')
  if state then
    -- Try to use totalPower directly
    local power = state.totalPower
    if not power or power == 0 then
      -- Fallback: calculate using I × U × √3 × cosφ
      local current = state.outputCurrent or 0
      power = (current * voltage * phases * cosFi) / 1000  -- in kW
    -- Send power (kW) to the configured KNX group address
    grp.write(station.ga, power)
    log('Could not retrieve status for ' .. station.name .. ' (' .. station.id .. ')')
