Threads: 65
Hello, any ideas on how to integrate this?
https://api.easee.cloud/index.html
I've found a Python script on github, is it possible to convert this in any way?
https://github.com/fondberg/pyeasee
Regards..
Threads: 43
This is a similar API: https://forum.logicmachine.net/showthread.php?tid=1786
There's a difference in login procedure (GetToken function). You need to set the 'content-type' header to 'application/json' and send username/password as json string:
Code: request_body= json.encode({
userName = 'aaa',
password = 'bbb',
Threads: 65
Thanks, it works.
What would be the best way if i wanted the connection to the API to stay active, and then run seperate scripts for various commands?
It's not best practise to request new tokens for every command.
Threads: 43
Create a scheduled script that will call GetToken() periodically and save the token into storage. All other scripts will use this token to make requests.
Check the expiresIn field that /api/accounts/token returns. It will tell for how many seconds the token is valid. Adjust scheduled script execution period accordingly.
Threads: 1
(15.04.2021, 19:56)tomnord Wrote: Thanks, it works.
Did you get your script to work?
Are you willing to share your script and the commands for the Easee charger?
Threads: 28
that would be very nice and would save me a lot of time :-)
Threads: 65
Works like a charm. I'll post when I have access to my LM again.
Threads: 1
(28.01.2022, 16:28)tomnord Wrote: Works like a charm. I'll post when I have access to my LM again.
Hi soo exaited about this!
Will you post it? Or sent it on PM?
Threads: 65
07.10.2022, 16:51
(This post was last modified: 07.10.2022, 16:52 by tomnord.)
Code: -- Load modules
require('json')
require('ssl.https')
require('ltn12')
-- Set credentials for Easee API
ChargerID = storage.get('EaseeAPI_ChargerID')
API_Token = storage.get('EaseeAPI_Token') --reads API Token from storage, The token is fetched from scheduled script: "Easee_Authenticate"
--log(ChargerID)
function RequestFromEasee(request)
request_url = 'https://api.easee.cloud/api/' .. request
local response_body = {}
local request_body = ""
local body, code, hdrs, stat = ssl.https.request{
url = request_url;
method = "GET";
headers =
["Content-Type"] = "application/json";
["Authorization"] = "Bearer " .. API_Token;
source = ltn12.source.string(request_body);
sink = ltn12.sink.table(response_body);
log(code)
if code == 200 then
ret = table.concat(response_body)
ret = json.pdecode(ret)
return ret
--API_Token = GetToken() -- request a new token
-- Get products, run once to get charger ID
if ChargerID == nil then
chargers = RequestFromEasee('chargers')
Easee_ChargerID = chargers[1]["id"]
--log(Easee_ChargerID, 'ID') -- Check here for your charger ID
storage.set('EaseeAPI_ChargerID', Easee_ChargerID)
ChargerState = RequestFromEasee('chargers/' .. ChargerID .. '/state')
log(ChargerState)
currentChargePower = ChargerState["totalPower"]
currentCableRating = ChargerState["cableRating"]
currentMaxPower = ChargerState["outputCurrent"]
chargerOnline = ChargerState["isOnline"]
currentChargeEnergy = ChargerState["sessionEnergy"]
log(currentChargePower, currentCableRating, currentMaxPower, chargerOnline, currentChargeEnergy)
function WriteToEasee(request, request_body)
local content_length
if type(request_body) == "string" then
content_length = #request_body
request_body = ""
url = request_url;
method = "POST";
headers =
["Content-Length"] = content_length;
log(code)
if code == 200 then
return ret
Code: require('json')
require('ltn12')
email ='****************'
password ='*************'
function GetToken()
request_token_url = 'https://api.easee.cloud/api/accounts/login'
local request_body = json.encode({
userName = email,
password = password,
url = request_token_url;
method = "POST";
headers =
["Content-Length"] = #request_body;
log(code)
if code == 200 then
log(ret)
return ret.accessToken
-- Request token
if not API_Token then
log(API_Token, 'api_token')
--Store API Token to memory
storage.set('EaseeAPI_Token', API_Token)
Threads: 7
29.06.2025, 19:38
(This post was last modified: 29.06.2025, 19:39 by johan84.)
Here is a script I use at a client's company to visualize the current charging power at each charging point in their company parking lot. Thank you tomnord for the earlier scrips
Code: -- Load required libraries once
require('json')
require('ltn12')
-- Your configuration
local API_Token = storage.get('EaseeAPI_Token')
-- Define all 8 charging stations with placeholder names, IDs and KNX group addresses
local chargingStations = {
{ name = 'charger 1', id = 'charger 1 id', ga = '55/1/1' },
{ name = 'charger 2', id = 'charger 2 id', ga = '55/1/2' },
{ name = 'charger 3', id = 'charger 3 id', ga = '55/1/3' },
{ name = 'charger 4', id = 'charger 4 id', ga = '55/1/4' },
{ name = 'charger 5', id = 'charger 5 id', ga = '55/1/5' },
{ name = 'charger 6', id = 'charger 6 id', ga = '55/1/6' },
{ name = 'charger 7', id = 'charger 7 id', ga = '55/1/7' },
{ name = 'charger 8', id = 'charger 8 id', ga = '55/1/8' },
-- Function for making a GET request to the Easee API
local function RequestFromEasee(endpoint)
local url = 'https://api.easee.cloud/api/' .. endpoint
local response = {}
local _, code = ssl.https.request{
url = url,
method = "GET",
headers = {
["Content-Type"] = "application/json",
["Authorization"] = "Bearer " .. API_Token,
sink = ltn12.sink.table(response),
if code == 200 then
return json.pdecode(table.concat(response))
log('Easee API error (' .. endpoint .. '): ' .. tostring(code))
return nil
-- Parameters for power calculation
local voltage = 230 -- V per phase
local phases = 3 -- three-phase
local cosFi = 0.95 -- power factor, adjust if needed
-- Loop over all charging stations
for _, station in ipairs(chargingStations) do
-- Fetch status
local state = RequestFromEasee('chargers/' .. station.id .. '/state')
if state then
-- Try to use totalPower directly
local power = state.totalPower
if not power or power == 0 then
-- Fallback: calculate using I × U × √3 × cosφ
local current = state.outputCurrent or 0
power = (current * voltage * phases * cosFi) / 1000 -- in kW
-- Send power (kW) to the configured KNX group address
grp.write(station.ga, power)
log('Could not retrieve status for ' .. station.name .. ' (' .. station.id .. ')')
