email?
I am using the standard script to send email. LM5 v20191015.
No matter what host I set in server, I get an error about "string: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8  https://support.google.com/mail/?p=BadCredentials c5sm15367699wrs.73 - gsmtp"
Why on earth would GOOGLE be there if I ask it to go to "sss" ???
How can I debug this?
I have tried all the combination of 'secure' found on the forum in various posts over the years; this is really confusing but in any case does not change anything since GOOGLE is always back as error.
Thanks for any help or pointers
  local settings = {
    from = '...',
    -- smtp username
    user = '...',
    -- smtp password
    password = '...',
    -- smtp server
    server = 'sss',
    -- smtp server port
    port = 465,
    secure = 'tlsv12',
    -- use STARTTLS mode
    --starttls = true,
  if type(to) ~= 'table' then
    to = { to }
  for index, email in ipairs(to) do
    to[ index ] = '<' .. tostring(email) .. '>'
  -- message headers and body
    headers = {
      to = table.concat(to, ', '),
      subject = subject,
      ['Content-type'] = 'text/html; charset=utf-8',
    body = message
  -- fixup from field
  settings.from = '<' .. tostring(settings.from) .. '>'
  settings.rcpt = to
  return smtp.send(settings)
Couple of things to check:
1) Make sure DNS and DG are set correct in the interface settings (otherwise you have no internet access)
2) Enable https://myaccount.google.com/lesssecureapps on your gmail account (otherwise mail from machines is blocked by google)
3) Use these settings in the common functions:
-- send an e-mail
  local settings = {
    from = 'yourmail@gmail.com',
    -- smtp username
    user = 'yourmail@gmail.com',
    -- smtp password
    password = 'yoursecretpassword',
    -- smtp server
    server = 'smtp.gmail.com',
    -- smtp server port
    port = 465,
    -- enable tls, required for gmail smtp
    secure = 'tlsv1_2',
    to = { to }
  -- fixup from field
  local from = '<' .. tostring(settings.from) .. '>'
    headers = {
      subject = subject,
      ['From'] = from,
    body = message
  settings.from = from
  settings.rcpt = to
  res, err = smtp.send(settings)
  return res,err
4) Send a mail
subject = 'E-mail test'
message = 'Testing e-mail'
res, err = mail('yourrecipient@gmail.com', subject, message)
