[OLD] LogicMachine firmware 2015.09.17
LM Reactor V2: http://dl.openrb.com/lm-15.09/reactorv2.img
LM Reactor: http://dl.openrb.com/lm-15.09/reactor.img
LM Reactor Lite: http://dl.openrb.com/lm-15.09/rctl.img
LM4: http://dl.openrb.com/lm-15.09/lm4.img
LM3 V2 (3 x RS-485 and 1 x RS-232): http://dl.openrb.com/lm-15.09/lm3v2.img
LM3 V1 (4 x RS-485): http://dl.openrb.com/lm-15.09/lm3v1.img
LM2 (All models): http://dl.openrb.com/lm-15.09/lm2-at91.img
(23.09.2015, 08:51)admin Wrote: LM Reactor V2: http://dl.openrb.com/lm-15.09/reactorv2.img
Edgards,
Could you please detail How to check the exact version your working with ?
Thanks,
Joris
In Logic Machine interface check left bottom corner, it will display the current version that your device is running.
Is there release note available to see whats new \ fixed?
Thanks,
Roger
The main new feature is the addition of Apps. Apart from that it's mostly a maintenance release with some minor bug fixes.
Can you please release some info how to write, share and possibly sell our own apps? Thanks
Full tutorials will be provided later on. All Apps are free for now and are published by sending application files to us.
Apps are written in JavaScript/HTML/CSS on client side and Lua on server side.
Please find attached short documentation on Apps and sample application. Upload sample folder to data directory by using FTP  with username apps (you have to enabled FTP and set password in System config first). After that you will have sample application visible on the main screen.
.pdf   apps.pdf (Size: 88.79 KB / Downloads: 88)
.zip   sample.zip (Size: 4.81 KB / Downloads: 24)
thank you
Ηι
I have a Logic machine 2 version Flash sys v2 r89 (05-10-12) is compatible with the version lm-15.09 / lm2-at91.img?
Τhanks,
Kostas
Quote:I have a Logic machine 2 version Flash sys v2 r89 (05-10-12) is compatible with the version lm-15.09 / lm2-at91.img?
It should work, but don't forget to make a full backup before upgrading. There might be some minor issues with visualization after the upgrade, everything else should work well.
I have not seen any updates regarding the LM4 software. Will it come a new release soon?
Currently I have the version 2015.09.
Regards,
Andreas
We're finishing the last testing phase, new release should be out very soon Smile
(04.04.2016, 08:34)admin Wrote: We're finishing the last testing phase, new release should be out very soon Smile
Any estimated release date for the new firmware? It's soon 4 weeks since you said very soon  Wink
@KingCanute: I guess that this was the topic you were looking for: http://forum.logicmachine.net/showthread.php?tid=292
