22.08.2025, 11:52
I believe you are correct! It works just fine, if I wait a bit for it...
[OLD] LogicMachine firmware 2025.08
22.08.2025, 11:52
25.08.2025, 09:39
(21.08.2025, 13:33)managementboy Wrote: I can't access the System Config since I flashed the beta... get a 404 error (21.08.2025, 13:35)Daniel Wrote: Cache? Did you try accessing via manual url typing? http://192.168.0.10/flashsys no matter what browser or PC I use I get the 404
25.08.2025, 10:24
Looks like you must flash the card. Something got corrupted.
02.09.2025, 11:19
02.09.2025, 11:22
Go to utilities and make a backup. You can send it to me if you want to check if it is not corrupted.
Ctrl+F5 I need to do in VISU whatI always done in old visualizzation: just a simple inputbox where to digit with keyboard. I mean I don't need any slider or spinner or other kind of widjet... How I can do? Thanks Peppe
03.09.2025, 12:25
Currently the only element which allows typing value is text input. We will see what can be done in next versions.
Which element did you use on old visu?
04.09.2025, 11:27
is there a chance to get the final Firmware for imx28 old CPU´s ?
04.09.2025, 11:37
Sorry but no chance. Last version is 2024.04
05.09.2025, 12:55
05.09.2025, 13:34
Looks like a proper corruption. Flash LM with new SD card and you can copy all files from the last partition from old to new SD card using Linux to restore your current project.
10.09.2025, 14:04
(05.09.2025, 12:55)managementboy Wrote:(02.09.2025, 11:19)managementboy Wrote:(25.08.2025, 10:24)Daniel Wrote: Looks like you must flash the card. Something got corrupted. worked like a charm. no need to copy anything as the cloud backup was perfect! thanks!
14.11.2025, 10:24
Perhaps this question would be more appropriate in the visualization thread. But there is a chance that my problem is somehow related to the firmware
After updating to the latest current version (for LM5p2-PMC), the Visu module does not work. When selecting Visu or Visu admin, a sector of a circle spins endlessly in the center of the gray screen (sorry, I couldn't hide this big picture under a spoiler): Removing and reinstalling the module from the .ipk-file did not change the situation. Everything else seems to be working as it should. Are there any tips to solve the problem?
14.11.2025, 10:26
Share your backap via PM. Not possible to say without having your configuration.
17.11.2025, 14:48
Hi everyone, and thanks in advance for any time and guidance you can share to help us resolve the unexpected reboots and intermittent trend-persistence issues we’re seeing on one of our LogicMachines. We’ll attach screenshots (System start alerts, trend charts, and system load) to illustrate the behavior.
[*]We’ve already reviewed forum threads on trend-save issues and spontaneous reboots. Most guidance focuses on power quality, SD integrity, and reducing the number/retention of trends. We’ve addressed all three (UPS supply, SD verified/writable with ample free space, trends drastically reduced), so our case seems unrelated to those common causes. [*]We would greatly appreciate any advice or collaboration to improve the system’s stability. We can share the full project and/or a complete device backup and run any tests you recommend to help diagnose and resolve the reboot and trend-persistence problems.
17.11.2025, 16:02
Send me your backup to PM and serial number of LM, see side label.
Yesterday, 07:47
I want to update my Logicmachine device. The details of my current version are as follows: HW: LM5 Lite (i.MX6) SW: 20211014 I have downloaded the latest update file, lm5m3-20240426. I want to perform the update, but I am encountering an error. I get the message: Cannot upgrade, "firmware image file is invalid". What is the reason for this?
Yesterday, 08:15
Did you try downloading it again? Reboot LM just in case too.
Yesterday, 09:25
Yes, I downloaded it again and also tried restarting the LogicMachine before updating. Unfortunately, the result is still the same @Daniel
Yesterday, 09:43
Are you downloading from the forum our from our website? Drop me a screenshot of the Upgrade firmware view.
Ctrl+F5 |
