[RC1] LogicMachine firmware 2025.08
#21
I believe you are correct! It works just fine, if I wait a bit for it...
(21.08.2025, 13:33)managementboy Wrote: I can't access the System Config since I flashed the beta... get a 404 error
(21.08.2025, 13:35)Daniel Wrote: Cache? Did you try accessing via manual url typing? http://192.168.0.10/flashsys
no matter what browser or PC I use I get the 404
Looks like you must flash the card. Something got corrupted.
(25.08.2025, 10:24)Daniel Wrote: Looks like you must flash the card. Something got corrupted.
do you have a How To? best if I don't loose all the work I've got on it
Go to utilities and make a backup. You can send it to me if you want to check if it is not corrupted.
I need to do in VISU whatI always done in old visualizzation: just a simple inputbox where to digit with keyboard.
I mean I don't need any slider or spinner or other kind of widjet...
How I can do?
Peppe
Currently the only element which allows typing value is text input. We will see what can be done in next versions.
Which element did you use on old visu?
is there a chance to get the final Firmware for imx28 old CPU´s ?
Sorry but no chance. Last version is 2024.04
I get this error
Looks like a proper corruption. Flash LM with new SD card and you can copy all files from the last partition from old to new SD card using Linux to restore your current project.
I get this error
worked like a charm. no need to copy anything as the cloud backup was perfect! thanks!
