Read/write file to LM5 connected USB
Hello, I am working with the logic machine 5 and I want to do a test of reading and writing files through a USB, but the example I find is focused on linux, does it work with windows? Or does it have a different syntax?
Another question, this code
- create usb mount directory
The.execute ('mkdir -p / mnt / usb')
- find first matching usb storage device
Dev = io.readproc ('ls / dev / sd * 1 2> / dev / null'): match ('/ dev / sd% l1')
- found it, mount
If dev then
The.execute ('mount' .. dev .. '/ mnt / usb')
Alert ('[usb-mount] mounted% s', dev)
- nothing found, local flash will be used
Else
Alert ('[usb-mount] no device found')
End
Hurt directly in the script or would relate to common functions?
Thank you.
Here you have a script for mounting USB:
part = '/dev/sda1' if io.exists(part) then  os.execute('mount ' .. part .. ' /mnt')  alert('mount ok') else  alert('usb disk not found') end
And this is for writing and reading a file from USB:
path = '/mnt/' status = io.exists(path) io.writefile(path .. 'new.txt', 'This is my new file.') result = io.readfile(path .. 'new.txt') log(status, result)
Smile
You have been very helpful, thank you.
This is from adminWink
Hi, I was working with that code but it is not writing to me in memory, it is only printing the message in the registers (logs), but in memory it does not write anything to me, what could happen?
What kind of task are you trying to achieve? If you want to store some data externally then FTP or remote database is a much better solution than a USB drive which is not designed for 24/7 operation.
Hi, what I want is to be able to write on an existing file from the logic machine, and also be able to read this, since I need to perform this task with USB at specific times.
Hi , a while ago I worked this example, I want to take it back, but it tells me that the connection is created but at the moment of writing in memory it does not, what error could I be presently presenting?
First, reboot your LM. Since you have tried different scripts your mount table is probably messed up. Second, make sure your flash drive is formatted as FAT or FAT32 (but not exFAT). Run this script once, then go to System Config > Status > System Status. In Partitions tab you should see that /dev/sda1 or similar is mounted under /mnt. Then you can use io.writefile('/mnt/myfile.txt', 'test') to write something onto USB drive.
1234567891011121314151617181920212223
devs = io.ls('/sys/class/block/') table.sort(devs) for _, dev in ipairs(devs) do   if dev:match('^sd%a%d$') then     part = dev     break   elseif not devn and dev:match('^sd%a$') then     devn = dev   end end part = part or devn if part then   os.execute('umount -f /mnt 2>&-')   res, stat = io.readproc('mount /dev/' .. part .. ' /mnt 2>&1')   if stat == 0 then     alert('USB mount OK')   else     alert('USB mount failed: ' .. tostring(res))   end else   alert('No valid USB devices found') end
Wink
It worked! Thanks, I really was very helpful. Big Grin Wink
