Read/write file to LM5 connected USB
Hello, I am working with the logic machine 5 and I want to do a test of reading and writing files through a USB, but the example I find is focused on linux, does it work with windows? Or does it have a different syntax?
Another question, this code
- create usb mount directory
The.execute ('mkdir -p / mnt / usb')
- find first matching usb storage device
Dev = io.readproc ('ls / dev / sd * 1 2> / dev / null'): match ('/ dev / sd% l1')
- found it, mount
If dev then
The.execute ('mount' .. dev .. '/ mnt / usb')
Alert ('[usb-mount] mounted% s', dev)
- nothing found, local flash will be used
Else
Alert ('[usb-mount] no device found')
End
Hurt directly in the script or would relate to common functions?
Thank you.
Here you have a script for mounting USB:
part = '/dev/sda1'
if io.exists(part) then
 os.execute('mount ' .. part .. ' /mnt')
 alert('mount ok')
 alert('usb disk not found')
And this is for writing and reading a file from USB:
path = '/mnt/'
status = io.exists(path)
io.writefile(path .. 'new.txt', 'This is my new file.')
result = io.readfile(path .. 'new.txt')
log(status, result)
Smile
You have been very helpful, thank you.
This is from adminWink
Hi, I was working with that code but it is not writing to me in memory, it is only printing the message in the registers (logs), but in memory it does not write anything to me, what could happen?
What kind of task are you trying to achieve? If you want to store some data externally then FTP or remote database is a much better solution than a USB drive which is not designed for 24/7 operation.
Hi, what I want is to be able to write on an existing file from the logic machine, and also be able to read this, since I need to perform this task with USB at specific times.
Hi , a while ago I worked this example, I want to take it back, but it tells me that the connection is created but at the moment of writing in memory it does not, what error could I be presently presenting?
First, reboot your LM. Since you have tried different scripts your mount table is probably messed up. Second, make sure your flash drive is formatted as FAT or FAT32 (but not exFAT). Run this script once, then go to System Config > Status > System Status. In Partitions tab you should see that /dev/sda1 or similar is mounted under /mnt. Then you can use io.writefile('/mnt/myfile.txt', 'test') to write something onto USB drive.
devs = io.ls('/sys/class/block/')
table.sort(devs)
for _, dev in ipairs(devs) do
  if dev:match('^sd%a%d$') then
    part = dev
    break
  elseif not devn and dev:match('^sd%a$') then
    devn = dev
part = part or devn
if part then
  os.execute('umount -f /mnt 2>&-')
  res, stat = io.readproc('mount /dev/' .. part .. ' /mnt 2>&1')
  if stat == 0 then
    alert('USB mount OK')
    alert('USB mount failed: ' .. tostring(res))
  alert('No valid USB devices found')
Wink
It worked! Thanks, I really was very helpful. Big Grin Wink
(30.03.2017, 06:50)admin Wrote: What kind of task are you trying to achieve? If you want to store some data externally then FTP or remote database is a much better solution than a USB drive which is not designed for 24/7 operation.
That’s interesting—what would be the most appropriate approach for handling the storage and access of high-frequency data (for example, every 30 seconds)? Would it be better to rely on a remote database (such as InfluxDB or PostgreSQL) rather than solutions like FTP?
What is the task you try to solve?
