email with attachement gives image size 0
I have a script that sends an email with attached foscam camera snaphots when my doorbell is pushed.
That works great for months, but after some time it crashed my lm4 as following:
- when my doorbell is pushed i receive an email with size 0 images. every doorbell push i receive that mail with size 0 image
- so i try to find the problem and test my code manual with a resident script (sleepinterval 60), the same code as my event-based script
require('user.nit_email')
mail({'test@test.nl'}, 'Test', 'Test message.', 'std_camera_2')
-I receive every 60 seconds an email, thats correct. But when i stop/deactivate this script i also receive every 60 seconds the email, why?
-So i need to restart my lm4 to solve this issue.
Nit_email
local from_name = 'HomeLynk'
local settings = {
   from = 'test@test.nl',
   -- smtp username
   --user = '',
   -- smtp password
   --password = '',
   -- smtp server
   server = '1.2.3.4',
   -- smtp server port
   port = 25,
   --secure = 'sslv23',
local escape = function(v)
 return '<' .. tostring(v) .. '>'
-- send an e-mail,
function mail(to, subject, message, att)
 if att then
   local mime = require('mime')
        local ltn12 = require('ltn12')
   -- generate attachements
   bodyAtt = handleAtt(att, 'start')
   bodyAtt = {"",""}
 if type(to) ~= 'table' then
   to = { to }
 for index, email in ipairs(to) do
   to[ index ] = escape(email)
   headers = {
     from = from_name..escape(settings.from),
     to = table.concat(to, ', '),
     subject = subject,
   body = {
       --preamble = "Hello Recipient, \r\n" .. "This is your e-mail with a picture attached.",
         header = {
           ['Content-type'] = 'text/html; charset=utf-8',
         body = mime.eol(0, message),
       bodyAtt[1],bodyAtt[2], -- get attachements if exists (max 2 for now)  <---todo:make it dynamic
       --epilogue = "That's it folks! :)"
 bodyAtt = nil
 -- fixup from field
 settings.from = escape(settings.from)
 settings.rcpt = to
 smtp.send(settings)
 if att then
   handleAtt(att, 'end')
-- std_camera: snapshot camera voordeur
-- std_camera_b: snapshot camera voordeur en achterdeur
function handleAtt(att, handle)
 if handle == "start" then
   if att == "std_camera" then
     require('user.nit_camera')
     dst = '/tmp/capture.jpg'
     local url = string.format(url_cmdFoscam, cam_voordeur, cam_port, 'snapPicture2', '', cam_usr2, cam_pwd2)
            local cmd = string.format('wget -O %q %q', dst, url)
            os.execute(cmd)
     local attachment = ltn12.source.chain( ltn12.source.file(io.open(dst, 'r')), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )
     return
         headers = {
           ['Content-type'] = 'image/jpeg; name="image.jpg"',
           ['Content-disposition'] = 'attachment; filename="image.jpg"',
           ['Content-transfer-encoding'] = 'BASE64',
         body = attachment
   elseif att == "std_camera_b" then
     dst1 = '/tmp/capture1.jpg'
     dst2 = '/tmp/capture2.jpg'
     local url1 = string.format(url_cmdFoscam, cam_voordeur, cam_port, 'snapPicture2', '', cam_usr2, cam_pwd2)
     local url2 = string.format(url_cmdFoscam, cam_achterdeur, cam_port, 'snapPicture2', '', cam_usr2, cam_pwd2)
            local cmd1 = string.format('wget -O %q %q', dst1, url1)
            local cmd2 = string.format('wget -O %q %q', dst2, url2)
     os.execute(cmd1)
            os.execute(cmd2)
     local attachment1 = ltn12.source.chain( ltn12.source.file(io.open(dst1, 'r')), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )
     local attachment2 = ltn12.source.chain( ltn12.source.file(io.open(dst2, 'r')), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )
     return
         headers = {
           ['Content-type'] = 'image/jpeg; name="image1.jpg"',
           ['Content-disposition'] = 'attachment; filename="image1.jpg"',
         body = attachment1
         headers = {
           ['Content-type'] = 'image/jpeg; name="image2.jpg"',
           ['Content-disposition'] = 'attachment; filename="image2.jpg"',
         body = attachment2
   elseif att == "std_camera_2" then
            local cmd2 = string.format('wget -O %q %q', dst2, url1)
     os.execute(cmd1) -- direct snapshot
     cmdFoscam(cam_voordeur, cam_port, 'ptzGotoPresetPoint', '&name=Deur') -- move to frontdoor
            os.sleep(20) -- wait for 20 seconds
     os.execute(cmd2) -- new snapshot
     return
         headers = {
         body = attachment1
         headers = {
         body = attachment2
 elseif handle == "end" then
     os.remove(dst)
     os.remove(dst1)
     os.remove(dst2)
     os.remove(dst1)
     os.remove(dst2)
Nit_camera
-- snapshot urls
cam_voordeur = '2.2.2.2'
cam_achterdeur = '2.2.2.3'
cam_port = 80
cam_usr = 'user'
cam_pwd = 'password'
cam_usr2 = 'user2'
cam_pwd2 = 'password2'
-- start command urls
url_cmdFoscam = 'http://%s:%s/cgi-bin/CGIProxy.fcgi?cmd=%s%s&usr=%s&pwd=%s'
-- Foscam camera command
function cmdFoscam(iCamera, iPort, iCmd, iParam)
 local url, response
 url = string.format(url_cmdFoscam, iCamera, iPort, iCmd, iParam, cam_usr, cam_pwd)
 if (url) then
     require('socket.http')
   socket.http.TIMEOUT = 5
   response = socket.http.request( url_encode(url) )
 return response
You should use LuaSocket to get a snapshot instead of wget. wget will fail if output file already exist so this might cause a problem with 0 sized attachments. There's no need to save snapshot to /tmp, you can use ltn12.source.string.
(26.10.2017, 09:06)admin Wrote: You should use LuaSocket to get a snapshot instead of wget. wget will fail if output file already exist so this might cause a problem with 0 sized attachments. There's no need to save snapshot to /tmp, you can use ltn12.source.string.
can you please give a little example?
You already have a function for HTTP requests, just get your snapshot by calling cmdFoscam and then pass the result like this:
local snapshot = cmdFoscam(...)
local attachment = ltn12.source.chain( ltn12.source.string(snapshot), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )
I've tried to use this script but I can´t get it to work.
function handleAtt(att)
if att == "snapshoot" then
local snapshoot = 'http://IPCAMERA/cgi-bin/snapshot.cgi?'
return
headers = {
body = attachment
The mail function send me a emai with jpg attachment but i can´t see anything.
When I use the link 'http://IPCAMERA/cgi-bin/snapshot.cgi?' i have to log in. How can I automatize with code?
Try like that
'http://user:password@IPCAMERA/cgi-bin/snapshot.cgi?'
(11.07.2018, 11:02)Daniel. Wrote: Try like that
It doesn´t work.
I´ve tried diferent options and every time ask me user and pass.
https://www.ispyconnect.com/man.aspx?n=Dahua
It doesn´t work.
You can try like here:
https://forum.logicmachine.net/showthrea...38#pid6338
Maybe your camera support such params:
http://IP_address/cgi-bin/snapshot.cgi?c...p=password
Done is better than perfect
It doesn´t work.
Don´t work..
My camera is IPC-HDBW1320E of Dahua and I try with both url of 'https://www.ispyconnect.com/man.aspx?n=Dahua':
It do something strange.. the first time I´ve tried the url it work and don´t ask me the user and pass, but once i use this url it doesn´t work..
I´ve tried with:
http://user:pass@CAMERAIP/cgi-bin/snapshot.cgi?1
http://admin:user@CAMERAIP/cgi-bin/snapshot.cgi?loginuse=user&loginpas=pass
http://admin:user@CAMERAIP/cgi-bin/snapshot.cgi?user=user&pass=pass
http://admin:user@CAMERAIP/cgi-bin/snapshot.cgi?user=user&pwd=pass
http://admin:user@CAMERAIP/cgi-bin/snapshot.cgi?u=user&p=pass
Can you try to add a fake parameter in the url like timestamp.
http://user:pass@CAMERAIP/cgi-bin/snapshot.cgi?1&ts=randomnumber
If it worked 1 time, and then fail, maybe there is a caching issue. By adding a parameter that change in the url, it is consider as a new request and will not look in the cache if any.
(11.07.2018, 18:21)mlaudren Wrote: Can you try to add a fake parameter in the url like timestamp.
Thanks!! this random number works perfectly. But with the script don´t attach the image correctly.. can you help me with the script?
Event-Based Script:
mail('MyEmail', 'ALERTA', '¡¡¡Alguien en casa!!!', 'captura')
Comon Functions:
function mail (to, subject, message, att)
  local settings = {
    from = '......',
    -- smtp username
    user = '.....',
    -- smtp password
    password = '......',
    -- smtp server
    server = 'smtp.gmail.com',
    -- smtp server port
    port = 465,
    -- enable tls, required for gmail smtp
    secure = 'tlsv1_2',
  local from_name = '.......'
  if att then
    bodyAtt = handleAtt(att) --bodyAtt = handleAtt(att, 'start')
    bodyAtt = {"",""}
    to = { to }
    headers = {
      subject = subject,
    body = {
          header = {
        --epilogue = "That's it folks! Smile"
  bodyAtt = nil
  -- fixup from field
  settings.rcpt = to
  smtp.send(settings)
    if att == "captura" then
    local snapshot = 'CAMERAIP'--..math.random(0, 1000000000000)
    log (snapshot)
    return
          headers = {
            ['Content-type'] = 'image/jpeg; name="Captura.jpg"',
            ['Content-disposition'] = 'attachment; filename="Captura.jpg"',
          body = attachment
Thanks!!!
I still don't know how to make a snapshoot from my ip camera and save or send it.
I have created a DNS to share the url in case you want to test it and help me. The camera is covered by privacy reasons...
IP : http://dnspruebacamara.myqnapcloud.com:5858/
user: admin
pass: 123456789
I have test it from web explorers (chrome or firefox) and it works perfectly from Them:
http://admin:123456789@dnspruebacamara.myqnapcloud.com:5858/cgi-bin/snapshot.cgi?1&ts=4561248/snapshot.jpeg
where ts=... is a random number that i must change by code, for the navigator not to ask me again the security credencials
.... But I can not get it work from the following code:
image_type = 'jpeg'
image_name_attachment = 'snapshot'
source_image_url = 'http://admin:123456789@dnspruebacamara.myqnapcloud.com:5858/cgi-bin/snapshot.cgi?1&ts=4561248/snapshot.jpeg'
--Get remote (from HTTP) image and put image file to HL (will be deleted when end of script)
os.execute('wget -O /www/scada/vis/' .. image_name_attachment .. '.' .. image_type .. ' ' .. source_image_url .. '')
or I have also tried this other code, and it did not work either:
image = socket.http.request(source_image_url)
I know that I am doing something wrong, but I dont know what I am missing.
Can anyone help me please???
Best regards
Your camera uses digest auth mechanism which is not supported by socket.http library.
Use this code to get your snapshot:
local skthttp = require('socket.http')
local skturl = require('socket.url')
local md5sum = require('encdec').md5
local hash = function(...)
  return md5sum(table.concat({...}, ':'))
local parse_header = function(header)
  local result = {}
  for key, value in (header .. ','):gmatch('(%w+)=(.-),') do
    if value:sub(1, 1) == '"' then -- strip quotes
      result[ key:lower() ] = value:sub(2, -2)
  return result
local make_digest_header = function(headers)
  local digest = {}
  for _, header in ipairs(headers) do
    if not header.unquote then
      header[ 2 ] = '"' .. header[ 2 ] .. '"'
    digest[ #digest + 1 ] = header[ 1 ] .. '=' .. header[ 2 ]
  return 'Digest ' .. table.concat(digest, ', ')
local _request = function(req)
  if not req.url then
    return nil, 'missing url'
  local url = skturl.parse(req.url)
  local user, password = url.user, url.password
  local sink = req.sink
  if not user or not password then
    return nil, 'missing credentials in url'
  url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil
  req.url = skturl.build(url)
  local source
  if req.source then
    local chunks = {}
    local capture = function(chunk)
      if chunk then
        chunks[ #chunks + 1 ] = chunk
      return chunk
    local chunk_id = 0
    source = function()
      chunk_id = chunk_id + 1
      return chunks[ chunk_id ]
    req.source = ltn12.source.chain(req.source, capture)
  req.sink = nil
  local body, code, hdrs = skthttp.request(req)
  if code == 401 and hdrs['www-authenticate'] then
    local ht = parse_header(hdrs['www-authenticate'])
    if not ht.realm or not ht.nonce then
      return nil, 'missing realm/nonce from response'
    local qop = ht.qop
    if qop and qop ~= 'auth' then
      return nil, 'unsupported qop ' .. tostring(qop)
    if ht.algorithm and ht.algorithm:lower() ~= 'md5' then
      return nil, 'unsupported algo ' .. tostring(ht.algorithm)
    local nc = '00000001'
    local cnonce = string.format('%08x', os.time())
    local uri = skturl.build({ path = url.path, query = url.query })
    local method = req.method or 'GET'
    local response = hash(
      hash(user, ht.realm, password),
      ht.nonce,
      nc,
      cnonce,
      'auth',
      hash(method, uri)
    req.headers = req.headers or {}
    local auth = {
      { 'username', user },
      { 'realm', ht.realm },
      { 'nonce', ht.nonce },
      { 'uri', uri },
      { 'cnonce', cnonce },
      { 'nc', nc, unquote = true },
      { 'qop', 'auth' },
      { 'algorithm', 'MD5' },
      { 'response', response },
    if ht.opaque then
      table.insert(auth, { 'opaque', ht.opaque })
    req.headers.authorization = make_digest_header(auth)
    if not req.headers.cookie and hdrs['set-cookie'] then
      -- not really correct but enough for httpbin
      local cookie = (hdrs['set-cookie'] .. ';'):match('(.-=.-)[;,]')
      if cookie then
        req.headers.cookie = '$Version: 0; ' .. cookie .. ';'
    if req.source then
      req.source = source
    req.sink = sink
  return body, code, hdrs
local request = function(url)
  local t = type(url)
  if t == 'table' then
    return _request(table.clone(url))
  elseif t == 'string' then
    local req = {}
    local _, code, headers = _request({ url = url, sink = ltn12.sink.table(req) })
    return table.concat(req), code, headers
url = 'http://admin:123456789@dnspruebacamara.myqnapcloud.com:5858/cgi-bin/snapshot.cgi?1&ts=123/snapshot.jpeg'
image, err, hdrs = request(url)
Thanks you!
It works perfectly
Best Regards
Hello!
I tried to adapt the script from post 13 to my task. But as a result, I get a file with an image, before which there is a piece of HTML code. In the logs we can see:
stest 25.02.2019 13:44:51
* string: <!DOCTYPE html>
<html><head><title>Document Error: Unauthorized</title></head>
<body><h2>Access Error: 401 -- Unauthorized</h2>
<p>Authentication Error</p>
</body>
</html>
As we can see, the authorization on the camera does not pass, but I still get the image. In order to view it, I only need to remove the html header.
So, I have to edit the image before sending it by mail. The solution is simple, but I think it is not quite right Wink
a1, a2 = string.find(image,"</html>\r\n")
image = string.sub(image, a2+1)
How to solve the problem correctly?
Thanks!
Your solution is correct, there's nothing else that can be done since the camera response is clearly wrong Smile
OK. Thank you!
(16.08.2018, 12:50)I tried to use this code, hopefully I put it in right. Didn\t flag any errors in the log, so that's hopeful.I can't find the url of where the snapshot is sent to... any help??admin Wrote: Your camera uses digest auth mechanism which is not supported by socket.http library.
  local result = {}
  return result
  local digest = {}
  if not req.url then
  local source
  if req.source then
    local chunks = {}
      if chunk then
      return chunk
    local chunk_id = 0
    source = function()
    if ht.qop ~= 'auth' then
      return nil, 'unsupported qop ' .. tostring(ht.qop)
      ht.nonce,
      nc,
      cnonce,
      'auth',
      hash(method, uri)
    local auth = {
      { 'uri', uri },
      { 'qop', 'auth' },
    if ht.opaque then
      if cookie then
    if req.source then
      req.source = source
  local t = type(url)
    local req = {}
Log what output the server produces. Add this to the end of the script:
log(image, err, hdrs)
In my case I have a file with a silly header:
<?xml version="1.0" encoding="UTF-8" ?>
<userCheck>
<statusValue>401</statusValue>
<statusString>Unauthorized</statusString>
</userCheck>
so I need to add:
a1, a2 = string.find(image,"</userCheck>\n")
to remove them.
