Scheduled script doesn't work
I have more scheduled (cron) scripts that works great. But when i add a new scheduled script its never executed.
I checked it with the following code: log('executed').
See attached image for my schedule settings
Firmware: 20151125
I had the same problem. Please try to reboot your system, it helps me in this case.
(27.07.2016, 11:23)Habib Wrote: Hi,
Reboot doesn't solve it.
and a cold boot (power Off and on)?
I think it's excactly the same problem than mine, see this post: http://forum.logicmachine.net/showthread.php?tid=337
In my case it's working only if I switch off the system and on again. admin means in my case, there is no difference between hot and cold boot.
Have you tried installing RC firmware? There's no difference between cold boot and software reboot.
(27.07.2016, 11:50)admin Wrote: Have you tried installing RC firmware? There's no difference between cold boot and software reboot.
I installed the latest RC firmware from the forum, now it works. But the version showed is: 20151125 (also after browser close/refresh/other browser)
Hmm, double check the firmware file. Resulting version should start with 201607. It might be an SD card issue, can you try installing a new one? Follow this guide: http://openrb.com/reflash-logicmachine3-...-software/
(27.07.2016, 12:49)admin Wrote: Hmm, double check the firmware file. Resulting version should start with 201607. It might be an SD card issue, can you try installing a new one? Follow this guide: http://openrb.com/reflash-logicmachine3-...-software/
This is a device with already a replaced sd card. I installed the firmware file again and now its updated.
