HL Public IP script
Until now I've used this script for the public IP change on HL:
ip_old = grp.getvalue('10/1/253')
require("socket.http")
myip = (socket.http.request("http://whatismyip.org/"))
ip = myip:match("[%font%-weight%: 600;\"%>](%d+%.%d+%.%d+%.%d+)")
if ip ~= ip_old then
 subject = 'HL has New Public IP'
 message = ip
 Email('my@email.com', subject, message)
grp.checkwrite('10/1/253', ip,dt.string)
Unfortunately whatismyip.org is closed and the script is not working.
Then I created this one:
ip = (socket.http.request("https://api.ipify.org"))
 message = ip
grp.checkwrite('10/1/253', ip, dt.string)
The csript is working in SciTE (or similar) in this version:
print (ip)
but NOT in HL.
What do I do wrong?!?
Try this:
require('socket.http')
socket.http.TIMEOUT = 5
local data = socket.http.request('http://api.ipify.org')
if not data then
return
log('No response getting IP')
ip_old = storage.get('ip_old')
if ip_old == nil then
storage.set('ip_old', data)
if data ~= ip_old then
log('IP changed, new IP is: ' .. data)
Working perfect.
Thank you FatMax!!!
You can remove the require(‘json’) because the script does not use it..
Removed.
It was there for other purposes of the script..
if not data then
return
ipPublic_old = storage.get('ipPublic_old')
if ipPublic_old == nil then
storage.set('ipPublic_old', data)
if data ~= ipPublic_old then
   subject = 'IP Pública'
  message = 'La nueva ip pública es: ' .. data
  mail('xxxxxxxxxxxx', subject, message)
Hi, I'm using this script and lately it was working fine but now I get notifications every little time (1-2 hours) and the IP has not changed. I receive an email notifying that the IP has changed but it appears blank, and after 60 seconds a second notification arrives with the same IP that I had previously.
Maybe run it less often, they might implement some limits.
