29.09.2024, 20:42
Hello everyone,
does anybody have the profile for the energymeter from ABB B23 112-10M?
Modbus profiles examples
29.09.2024, 20:42
Hello everyone,
06.10.2024, 13:02
Good morning Community,
I want to share for all user an Huawey Sun2000 modbus profile. Tested with a 20 sec of polling and it works. All the contributes are welcome. Best regards Cristian
25.10.2024, 06:48
I want to share for all user an Caleffi Conteca modbus profile and pdf useful for solve any doubt. All the contributes are welcome. Best regards, Mirko
20.11.2024, 13:31
21.11.2024, 13:37
If you need a profile for ABB B23 112-10M then we can help with creating it.
05.01.2025, 10:42
(This post was last modified: 09.01.2025, 16:29 by CristianAgata.)
(06.10.2024, 13:02)CristianAgata Wrote: Good morning Community, Hi everybody, I post a little update to the profile with some fixed point. BR Cristian (05.01.2025, 10:42)CristianAgata Wrote:(06.10.2024, 13:02)CristianAgata Wrote: Good morning Community, Thanks for sharing but i got invalit profile error if i import triface , but mono works
09.01.2025, 16:28
(09.01.2025, 16:19)atomi23 Wrote:(05.01.2025, 10:42)CristianAgata Wrote:(06.10.2024, 13:02)CristianAgata Wrote: Good morning Community, Try this
09.01.2025, 16:32
(09.01.2025, 16:28)CristianAgata Wrote:(09.01.2025, 16:19)atomi23 Wrote:(05.01.2025, 10:42)CristianAgata Wrote:(06.10.2024, 13:02)CristianAgata Wrote: Good morning Community, Thanks for your Work it works now Ok now i have to test it on my installation ( it will take some time becouse of the weather at the moment
11.01.2025, 06:36
I am trying to connect my Gree Versati IV heat pump with LogicMachine Reactor through Modbus. I can read the values of registers from Read Test button on modbus tab inside the interface of logicmachine. I would like some help to make the rest procedure to get these values on the knx bus. Thank you.
13.01.2025, 08:52
(11.01.2025, 06:36)kyriakos@webros.gr Wrote: Hello, Create separate thread for this and we can help you start.
12.02.2025, 21:09
my basic profile and info I found about Sungrow inverter SH8.0RT-V112. Will update more a bit later. Also found that some data has different names in pdf file and iSolarCloud app (from Sungrow). Some of data in iSolarCloud is just sum of some other parameters.. We can discuss it later, I have a site with this device.
Communication Protocol of Residential Hybrid Inverter-V1.1.5.pdf (Size: 432.13 KB / Downloads: 15)
SunGrow_.json (Size: 4.82 KB / Downloads: 18)BR, Alexander
19.02.2025, 19:10
Someone asked for a Profile for PowerTag I/O module.
For the control object, ON = 2. OFF = 1. For the status object, 0 = false, 1 = true
Arkitecht_PowerTagIo.json (Size: 383 bytes / Downloads: 11)
31.03.2025, 12:03
Dear Sir ,
We Have Installed KNX System With Logic Machine .Scada Team Wants to Operate Light with Scene Group Address from Modbus RS485 From Logic Machine They Need Mapped group Address, Baud rate, parity, Addresses form us. How do we map 1bit and 1 byte group address to Logic machine. can you provide json profile for light group address where we map that group address.
31.03.2025, 12:50
Please always create new thread when asking question not related to the topic.
Most likely you need this: https://kb.logicmachine.net/integration/...tcp-slave/
01.04.2025, 08:26
(10.03.2023, 10:12)pritorianz Wrote: Hi all! Hi! I made almost the same profile, and then found yours. I added multiple writes, hid the air conditioner number (according to the documentation it is always 0, so I set the mode to "internal") and changed "bus_datatype" to "temperature" in the corresponding addresses.
01.04.2025, 08:40
(01.04.2025, 08:26)provodkapro Wrote:(10.03.2023, 10:12)pritorianz Wrote: Hi all! Next time use this: https://forum.logicmachine.net/showthread.php?tid=5911
15.04.2025, 12:46
Can someone help me? It's about the Pego refrigerator's modbus integration. Pego communicates with RTU 2-wire. Both W4K and Pego have 120 ohm termination resistors. Pego is the only device in the RTU. The following registers are in use: - 256 int16 - 768 int16 - 1280 (Bitmap) - 1281 (Bitmap) - 1282 (Bitmap) Modbus reports random CRC and read errors I tried to read values with the read test, but I don't get an error message then. What can I do next? What could be wrong with the Modbus profile? Attached: Pego modbus instructions (pdf) and a created modbus profile (json) |
