Modbus profiles examples
#81
Hello everyone,
does anybody have the profile for the energymeter from ABB B23 112-10M?
Good morning Community,
I want to share for all user an Huawey Sun2000 modbus profile.
Tested with a 20 sec of polling and it works.
All the contributes are welcome.
Best regards Cristian
.json   Huawei SUN2000_monofase.json (Size: 5.05 KB / Downloads: 20)
I want to share for all user an Caleffi Conteca modbus profile and pdf useful for solve any doubt.
Best regards,
Mirko
.pdf   01306_IT_0.pdf (Size: 5.33 MB / Downloads: 18)
.json   Caleffi Conteca.json (Size: 5.07 KB / Downloads: 21)
.pdf   Modbus settings.pdf (Size: 997.47 KB / Downloads: 25)
(29.09.2024, 20:42)Sjef de Laat Wrote: Hello everyone,
Did you get the profile for that meter?
If you need a profile for ABB B23 112-10M then we can help with creating it.
(06.10.2024, 13:02)CristianAgata Wrote: Good morning Community,
Hi everybody,
I post a little update to the profile with some fixed point.
BR Cristian
.json   Huawei SUN2000_Mono_V28122024.json (Size: 5.4 KB / Downloads: 11)
.json   Huawei SUN2000_trifase_V09012025.json (Size: 5.62 KB / Downloads: 7)
Hi everybody,
BR Cristian
Thanks for sharing but i got invalit profile error if i import triface , but mono works
Hi everybody,
BR Cristian
Try this
.json   Huawei SUN2000_trifase_V09012025.json (Size: 5.62 KB / Downloads: 19)
Hi everybody,
BR Cristian
Try this
Thanks for your Work it works now Wink Ok now i have to test it on my installation Wink ( it will take some time becouse of the weather at the moment Wink
I am trying to connect my Gree Versati IV heat pump with LogicMachine Reactor through Modbus. I can read the values of registers from Read Test button on modbus tab inside the interface of logicmachine. I would like some help to make the rest procedure to get these values on the knx bus.
Thank you.
(11.01.2025, 06:36)kyriakos@webros.gr Wrote: Hello,
Thank you.
Create separate thread for this and we can help you start.
my basic profile and info I found about Sungrow inverter SH8.0RT-V112.
Will update more a bit later. Also found that some data has different names in pdf file and iSolarCloud app (from Sungrow). Some of data  in iSolarCloud  is just sum of some other parameters.. We can discuss it later, I have a site with this device.
.json   SunGrow_.json (Size: 4.82 KB / Downloads: 11)
Alexander
(21.11.2024, 13:37)admin Wrote: If you need a profile for ABB B23 112-10M then we can help with creating it.
Hello tank you,
I now made it with your modbus generator and it works perfectly now
Someone asked for a Profile for PowerTag I/O module.
For the control object, ON = 2. OFF = 1.
For the status object, 0 = false, 1 = true
.json   Arkitecht_PowerTagIo.json (Size: 383 bytes / Downloads: 9)
Dear Sir ,
We Have Installed KNX System With Logic Machine .Scada Team Wants to Operate Light with Scene Group Address from Modbus RS485 From Logic Machine They Need Mapped group Address, Baud rate, parity, Addresses form us. How do we map 1bit and 1 byte group address to Logic machine. can you provide json profile for light group address where we map that group address.
Please always create new thread when asking question not related to the topic.
Most likely you need this:
https://kb.logicmachine.net/integration/...tcp-slave/
(10.03.2023, 10:12)pritorianz Wrote: Hi all!
I made and checked the profile for the Haier YCJ-A002 module (for connecting Haier air conditioners via Modbus).
For writing, I used the site https://jsoneditoronline.org/
And modbus profile generator https://forum.logicmachine.net/showthrea...8#pid19678
Hi!
I made almost the same profile, and then found yours.  Big Grin
I added multiple writes, hid the air conditioner number (according to the documentation it is always 0, so I set the mode to "internal") and changed "bus_datatype" to "temperature" in the corresponding addresses.
.json   Haier YCJ-A002.json (Size: 2.21 KB / Downloads: 1)
Hi!
Next time use this:
https://forum.logicmachine.net/showthread.php?tid=5911
Profile for Genvex Optima 251
.json   Genvex_OPTIMA251.json (Size: 58.19 KB / Downloads: 2)
