22.08.2025, 11:52
I believe you are correct! It works just fine, if I wait a bit for it...
[RC1] LogicMachine firmware 2025.08
22.08.2025, 11:52
25.08.2025, 09:39
(21.08.2025, 13:33)managementboy Wrote: I can't access the System Config since I flashed the beta... get a 404 error (21.08.2025, 13:35)Daniel Wrote: Cache? Did you try accessing via manual url typing? http://192.168.0.10/flashsys no matter what browser or PC I use I get the 404
25.08.2025, 10:24
Looks like you must flash the card. Something got corrupted.
02.09.2025, 11:19
02.09.2025, 11:22
Go to utilities and make a backup. You can send it to me if you want to check if it is not corrupted.
Ctrl+F5 I need to do in VISU whatI always done in old visualizzation: just a simple inputbox where to digit with keyboard. I mean I don't need any slider or spinner or other kind of widjet... How I can do? Thanks Peppe
03.09.2025, 12:25
Currently the only element which allows typing value is text input. We will see what can be done in next versions.
Which element did you use on old visu?
04.09.2025, 11:27
is there a chance to get the final Firmware for imx28 old CPU´s ?
04.09.2025, 11:37
Sorry but no chance. Last version is 2024.04
05.09.2025, 12:55
05.09.2025, 13:34
Looks like a proper corruption. Flash LM with new SD card and you can copy all files from the last partition from old to new SD card using Linux to restore your current project.
10.09.2025, 14:04
(05.09.2025, 12:55)managementboy Wrote:(02.09.2025, 11:19)managementboy Wrote:(25.08.2025, 10:24)Daniel Wrote: Looks like you must flash the card. Something got corrupted. worked like a charm. no need to copy anything as the cloud backup was perfect! thanks! |
