HL Public IP script
Until now I've used this script for the public IP change on HL:
ip_old = grp.getvalue('10/1/253') require("socket.http") myip = (socket.http.request("http://whatismyip.org/")) ip = myip:match("[%font%-weight%: 600;\"%>](%d+%.%d+%.%d+%.%d+)") if ip ~= ip_old then  subject = 'HL has New Public IP'  message = ip  Email('my@email.com', subject, message) end grp.checkwrite('10/1/253', ip,dt.string)
Unfortunately whatismyip.org is closed and the script is not working.
Then I created this one:
ip_old = grp.getvalue('10/1/253') require("socket.http") ip = (socket.http.request("https://api.ipify.org")) if ip ~= ip_old then  subject = 'HL has New Public IP'  message = ip  Email('my@email.com', subject, message) end grp.checkwrite('10/1/253', ip, dt.string)
The csript is working in SciTE (or similar) in this version:
require("socket.http") ip = (socket.http.request("https://api.ipify.org")) print (ip)
but NOT in HL.
What do I do wrong?!?
Try this:
require('socket.http') socket.http.TIMEOUT = 5 local data = socket.http.request('http://api.ipify.org') if not data then return log('No response getting IP') end ip_old = storage.get('ip_old') if ip_old == nil then storage.set('ip_old', data) end if data ~= ip_old then storage.set('ip_old', data) log('IP changed, new IP is: ' .. data) end
Working perfect.
Thank you FatMax!!!
You can remove the require(‘json’) because the script does not use it..
Removed.
It was there for other purposes of the script..
require('socket.http') socket.http.TIMEOUT = 5 local data = socket.http.request('http://api.ipify.org') if not data then return log('No response getting IP') end ipPublic_old = storage.get('ipPublic_old') if ipPublic_old == nil then storage.set('ipPublic_old', data) end if data ~= ipPublic_old then storage.set('ipPublic_old', data) log('IP changed, new IP is: ' .. data) end if data ~= ipPublic_old then    subject = 'IP Pública'   message = 'La nueva ip pública es: ' .. data   mail('xxxxxxxxxxxx', subject, message)   storage.set('ipPublic_old', data) end
Hi, I'm using this script and lately it was working fine but now I get notifications every little time (1-2 hours) and the IP has not changed. I receive an email notifying that the IP has changed but it appears blank, and after 60 seconds a second notification arrives with the same IP that I had previously.
Maybe run it less often, they might implement some limits.
Did you solve the problem?
